In Win Dragon Rider
419 4
I've pretty much settled on this case, all I need to do is clarify that a pair of internal exhaust video cards will not pose a problem in this case. I plan on using the MSI N580GTX Lightning Xtremes and I want to make sure I will not encounter any cooling problems with the In Win Dragon Rider.
1 - 5 of 5 Posts
the case is very quiet and the side fan moves a pretty good amount of air, the 120mm fans throughout the case do not move that much air, but the fact that the top is mesh really helps to keep things cool. If you really want to go as cool as possible then I would probably suggest upgrading the 120's but it is by no means a must
1 - 5 of 5 Posts
