Increase access times?
826 Views 22 Replies 11 Participants Last post by  IdPlease
I score around 12.7ms on HT Tune. I hear that if you create small partitions, it increased the Access speed. I was hoping to create a small partition of around 60GB to fit 2 to 3 most played games to help on load times. Can this be done without reformating the drive? I am a HD noob. Also, does raid speed up access time?
1 - 20 of 23 Posts
Why do you want to increase access times? That'll make your games load slower.
No, smaller partitions will DECREASE access times. The read/write head has less area to search.
The whole idea is to put what you want fast access for on the outer most part of the HDD platter. Even though the whole platter spins at the same RPM, the sectors go buy the head at a greater speed near the outer edge.
Defragging may have a greater influence on game load times though, depending on how fragmented your drive(s) is/are.
Yes, you can create a new partition, but putting it at the outer edge would be safer and easier with an OS reinstall.
RAID0 will sped up access times greatly, RAID1 wont.
Have a look at Ultimate Defrag. It lets you put whatever you want wherever you want it.
You've Never Seen Such Power and Flexibility In A Defragger! File Placement Options For Hard Drive Performance Optimization To FulFill Your Wildest Dreams..... And To Squeeze Every Millisecond of Performance From Your Hard Drive.
It's called Short Stroking.
Raid won't change access times whatsoever.
This.
Although the read and write speeds up in RAID, the harddrives still take the same amount of time to access the information on the drives, due to the head that reads the disk on the drive not having any speed boosts due to RAID (just not physically possible).
Originally Posted by blackspirerider View Post
i think he meant to say decrease access times...or increase access speed....
LOL
We knew that.
RAID actually can increases access times due to additional latency.
Originally Posted by xxicrimsonixx View Post
This.
LOL
We know that. But the OP said he was a nOOb, so I didn't want to go into details. Ultimate Defrag will confuse him enough.
ultimate defrag will confuse him enough.
:d
To be fair, he did not say anything wrong here at all.
Increasing access speed (although not particularly technical), is not wrong, and is exactly what you want to do with your storage.
Speeding up access time, again although a little clunky, is not really incorrect either.
I am sure there are occasions when some of those pointing and laughing have not got their terminology spot on. Maybe a little more leeway in future? The guy got his point across perfectly...
Mine's never spot on but I was laughing at the Ultimate Defrag comment.
The options on that program are enough to keep an experienced user occupied for days....Ask me how I know!
My comment wasn't aimed at you - more at those a little earlier in the thread.
But I am not trying to single people out - just promote a little more friendliness. After all, we are all here because we spend too much time/money on our pcs anyway - we might as well all get along...
Bradley,
SSDs will help in that respect. Make a RAID0 with 2 SSDs and you'll see what your system can do. Classical HDD's only slow down most of our computers. Spin, move needles, etc.
When prices go down, jump on a few INTELS
. That is what I will do
. 420 euros is a bit much for an INTEL drive
The cheaper and quicker option would be to create a small partition and install my most 2 played games on it to help on load times. How do i create a partitiion on the outer edge of the platter without loosing any information on the HDD? Thank you.
Get the amount of data on your partition down as much as possible. Then use Windows Disk Management to shrink your partition down. You might need to repeat a few times, and you may need to use a third party defragger with decent space consolidation options to shrink down.
And i won't lose data or confuse any file path/locations will i?
Nope.
Windows disk management will only allow you to make the partition as small as the data on it, not smaller.
All the files on your drive and the links / directories will continue to work as before. You will just have less Free Space.
As with anything tho, it always best to create a BACKUP of your data.
It a good habit to get into also, takes minutes to backup your data and can save hours of work.
It a good habit to get into also, takes minutes to backup your data and can save years of work.
Fixed
1 - 20 of 23 Posts
