1 - 4 of 4 Posts
Hey all
Another question. Our fileserver (virtual machine) is running low on disk space, so I accessed the VMWare server that hosts the machine, and increased the alotted disk space by 100GB.
Windows recognizes it as a new partition. Now, I need to add that 100GB to an existing partition, but Windows Server 2003 doesn't have that capability.
Anybody know of freeware software that will do it, and that doesn't require a reboot?
What would you system admins recommend?
Originally Posted by archangelabove
Hey all
Windows Server 2003 has the ability, just not through the Disk Management GUI. You have to use the DISKPART command-line utility.
Reference: http://support.microsoft.com/kb/325590
As good practice, you should be doing this after business hours, and after you've checked you have a good backup of the data set.
I used a gparted ISO.
Just boot the VM with the ISO and do what you would normally do as if it was a real hard drive.
But of course this requires a reset.
1 - 4 of 4 Posts
