Tec insulating Guide
By omaryunus
Well as most of you know been working hard on my comp for the past few weeks and well Ive been insulating my board along the way… so I decided I would make a little guide out of it since there really isn’t a recent one around and I want more ppl to get into this and see how easy this is
This is more of a follow the pics of what I did more than this is what you have to do and blah blah
Well here goes:
First a list of things you need to insulate your mobo:
1)NEOPRENE!! (LOATS OF IT) just in case
2)Conformal Coating
3)Dielectric Grease
4)Silicone rubber Adhesive
5) Liquid Electric Tape
First for any good TEC block or setup you need a good… back plate
EK makes a nice one and it works perfectly
cut out a piece of neoprene to go along the back of the mobo so no air comes in there
Screws in and good to go
This is how it looks now
Enough with the backplate moving on to the back of the board
wipe the back of the board clean
now with the Conformal coating (if you have a tube this is how it will go)
here is a pic from ira-k which shows the conformal zone on the back of the mobo so this should help:
a nice thick layer of conformal coating in the conformal zone (shown above)
another view just to show you from a diff angle
and now to the front:
use the silicone rubber adhesive
heres how it starts
and done
Diff views
view from the top
and now use the Dow conformal again on the front
here is another pic from ira-k which shows you the Conformal zone
heres how it should look put it on nice and thick
Closer looks:
and well one thing which the EK backplate is not good for is keeping the neoprene down in the back so you can use some of the electric liquid tape
lifted up we need to bring it down
and down
good pic
now to the neoprene layers :d
second layer on and test fitted
ready to install the CPU
continued on next post...
By omaryunus
Well here goes:
2)Conformal Coating
3)Dielectric Grease
heres how it starts
and done
Diff views
view from the top
Closer looks:
and down
good pic
