I've had the chip at 5Ghz, although only during bench runs.Originally Posted by $ilent;14728540
It might just be that your chip might not be able to get to 5ghz? Keep increasing vcore until you can run p95. There isn't really any magic setting, either you will be able to boot and fail during stress testing, in which case tweaking with voltages will help.
Those temps are fine. Pretty respectable in fact. Very few programs heat a CPU like prime95.Originally Posted by devvfata1ity;14747707
any idea about the temps I am getting? During prime95 i get 67c on the hottest core but during normal operation (read lots of gaming) I get 60-61C on the hottest core. Are these temps ok? I am at 4.5ghz - 1.30v. My ambient is ~27-28C. Room is non AC
Thats your cpu downclocking at idle, try turning off speedstep and c1e. It should stay at your overclock speed now.Originally Posted by danielwiley;14746262
http://valid.canardpc.com/show_oc.php?id=1973980
this is what happens when I try and take my 2500k to 4.2. there must be some setting in the bios i goofed up. I followed these steps exactly from a bone stock setting. the only thing I changed is the multi from 4.8 to 4.2 because of my shoddy cooling situation for the time being. i used "two cables" template, followed those steps exactly from a stock setting. Idk anything about intel, this is my first intel chip since high school. is there something I missed ? Does the i5 cut down on the overclocking when it's in a near idle state ? thanks for your help guys.
http://www.overclock.net/intel-motherboards/1012874-official-asus-p8p67-p8z68-series-owners.html
the steps I followed are here, about half way down the page.
There not bad, could be better for sure. I think your hot ambient probably isnt helping. For reference I get just a couple C more during my p95 and thats at 1.4v.Originally Posted by devvfata1ity;14747707
Yeah i definitely plan on getting IB when its out!Originally Posted by L D4WG;14747849
Awesome guide for us beginners, perhaps if I get a 2600k ill look back, but im more inclined to wait it out, hopefully you make another guide for Ivy bridge CPU!!
If you set your vcore to 1.70, in windows it might drop to 1.684/1.690 for instance with a good LLC setting, but it wouldnt stray too far from your setting in bios. However, you go by what cpu-z says in windows, the actual volt is what you see in windows, not what you set in bios due to vdroop and the loss of voltages to prevent the cpu from being overvolted when under load.Originally Posted by Deathtrip2k;14749349
ok i have a question, if i set my vcore to 1.4 with LLC level 5 i get 1.404v in windows. And if i set my vcore to 1.45 without LLC i get the same. Does it matter if i set my vcore in bios to (let's exaggerate alot) 1.7v aslong as its within the safe volt in windows?
I have a i5 2500K, what does [email protected] mean?Intel Virtualization Technology - AFAIK This is only necessary for [email protected] on a 2500k
This is why you get a higher-quality board with better VRM's.Originally Posted by Ascii Aficionado;14716474
Using this guide showed me the 4.5 OC I thought I had stable actually wasn't, It's now rock solid.
I get the feeling it's going to be extremely tedious to go past 4.5 with 100% stability.
