hi,
i tryed raid for the first time a few days ago.
i had a question about stripe size but nobody could really awnser it
On alot of forums this question is been asked but none give's a clear awnser.
Sadly enough after my little test i dont have it either really.
But with the info given you can maybe make up your own mind and pick whats best
Test system:
-i7-860 @ 3,8ghz
-4GB RAm @ 1824mhz
-Asus P7P55D Premium board
-2X Intel X25-M 80GB SSD's
not going to name all system parts becuase they dont matter for this test.
The ssd's are connected to the ICH10R controller of the mainboard P55 chipset.
The test:
simple basic test with just AS SSD benchmark.
We will be testing 128K, 64K,16K and 4K stripe sizes.
Also test difference between write cache disabled and enabled.
everywhere you ask people say have your wite cache disabled, i think this test shows otherwise
128K stripe size and cache disabled
128K stripe size and cache enabled
64K stipe size and cache disabled
64K stripe size and cache enabled
16K stripe size and cache disabled
16K stripe size and cache enabled
4K stripe size and cache disabled
not much different in stripe sizes but it seems to me 64K is best. and it looks like you loose a little bit performance when you go smaller stripe size's
what does make a huge difference is the write cache.
I been reading everywhere people saying turn it of for better performance but i think this little test has proven differently.
attleast i am sticking with 64K stripe size and cache enabled
again this thread is just for info
Test system:
-i7-860 @ 3,8ghz
-4GB RAm @ 1824mhz
The test:
