1 - 5 of 5 Posts
[06:46:09] Quit 101 - Fatal error: NaN detected: (ener[13])
[06:46:09]
[06:46:09] Simulation instability has been encountered. The run has entered a
[06:46:09] state from which no further progress can be made.
[06:46:09] This may be the correct result of the simulation, however if you
[06:46:09] often see other project units terminating early like this
[06:46:09] too, you may wish to check the stability of your computer (issues
[06:46:09] such as high temperature, overclocking, etc.).
What's this here? I'm 9+ hours prime stable, and I'm pretty sure I've never seen an error like this before. Ugh, this was on a Double Gromacs core too...600+ points.
[01:41:04] Gromacs cannot continue further.
[01:41:04] Going to send back what have done.
[01:41:04] logfile size: 13465
[01:41:05] - Writing 14001 bytes of core data to disk...
[01:41:05] ... Done.
[01:41:06]
[01:41:06] [email protected] Core Shutdown: EARLY_UNIT_END
[01:41:10] CoreStatus = 72 (114)
[01:41:10] Sending work to server
[01:41:10] + Attempting to send results
[01:41:11] + Results successfully sent
[01:41:11] Thank you for your contribution to [email protected]
[01:41:15] - Preparing to get new work unit...
[01:41:15] + Attempting to get work packet
[01:41:15] - Connecting to assignment server
[01:41:16] - Successful: assigned to (171.65.103.150).
[01:41:16] + News From [email protected]: Welcome to [email protected]
[01:41:16] Loaded queue successfully.
[01:41:24] + Closed connections
[01:41:29]
[01:41:29] + Processing work unit
[01:41:29] Core required: FahCore_79.exe
[01:41:29] Core found.
[01:41:29] Working on Unit 05 [February 22 01:41:29]
[01:41:29] + Working ...
[01:41:43]
[01:41:43] *------------------------------*
[01:41:43] [email protected] Double Gromacs Core
[01:41:43] Version 1.72 (February 4, 2005)
[01:41:43]
[01:41:43] Preparing to commence simulation
[01:41:43] - Looking at optimizations...
[01:41:49] - Created dyn
[01:41:49] - Files status OK
[01:42:34] - Expanded 1168901 -> 4020229 (decompressed 343.9 percent)
[01:42:45] - Starting from initial work packet
[01:42:52]
[01:42:52] Project: 2387 (Run 2, Clone 15, Gen 6)
[01:42:52]
[01:43:43] Assembly optimizations on if available.
[01:43:43] Entering M.D.
[01:44:16] Protein: p2387_Ubiquitin
[01:44:16]
[01:44:21] Writing local files
[02:25:24] Extra SSE2 boost OK.
[02:26:22] Writing local files
[02:26:31] Completed 0 out of 500000 steps (0)
[02:26:42] Quit 101 - Fatal error: NaN detected: (ener[18])
[02:26:42]
[02:26:42] Simulation instability has been encountered. The run has entered a
[02:26:42] state from which no further progress can be made.
[02:26:42] This may be the correct result of the simulation, however if you
[02:26:42] often see other project units terminating early like this
[02:26:42] too, you may wish to check the stability of your computer (issues
[02:26:42] such as high temperature, overclocking, etc.).
[02:26:43] Going to send back what have done.
[02:26:43] logfile size: 8070
[02:26:49] - Writing 8633 bytes of core data to disk...
[02:26:49] ... Done.
[02:26:57]
[02:26:57] [email protected] Core Shutdown: EARLY_UNIT_END
[02:27:00] CoreStatus = 72 (114)
[02:27:00] Sending work to server
[02:27:00] + Attempting to send results
[02:27:00] + Results successfully sent
[02:27:00] Thank you for your contribution to [email protected]
[02:27:25] - Preparing to get new work unit...
[02:27:25] + Attempting to get work packet
[02:27:25] - Connecting to assignment server
[02:27:25] - Successful: assigned to (171.65.103.150).
[02:27:25] + News From [email protected]: Welcome to [email protected]
[02:27:25] Loaded queue successfully.
[02:27:32] + Closed connections
[02:27:37]
[02:27:37] + Processing work unit
[02:27:37] Core required: FahCore_79.exe
[02:27:37] Core found.
[02:27:37] Working on Unit 06 [February 22 02:27:37]
[02:27:37] + Working ...
[02:27:49]
[02:27:49] *------------------------------*
[02:27:49] [email protected] Double Gromacs Core
[02:27:49] Version 1.72 (February 4, 2005)
[02:27:49]
[02:27:49] Preparing to commence simulation
[02:27:49] - Looking at optimizations...
[02:27:49] - Created dyn
[02:27:49] - Files status OK
[02:28:44] - Expanded 723166 -> 3678233 (decompressed 508.6 percent)
[02:28:44] - Starting from initial work packet
[02:28:44]
[02:28:44] Project: 2388 (Run 1, Clone 108, Gen 0)
[02:28:44]
[02:29:32] Assembly optimizations on if available.
[02:29:32] Entering M.D.
[02:30:28] Protein: p2388_CI2
[02:30:28]
[02:30:38] Writing local files
[02:58:59] Extra SSE2 boost OK.
[02:59:24] Writing local files
[02:59:34] Completed 0 out of 500000 steps (0)
[03:02:45] Quit 101 - Fatal error: NaN detected: (ener[13])
[03:02:45]
[03:02:45] Simulation instability has been encountered. The run has entered a
[03:02:45] state from which no further progress can be made.
[03:02:45] This may be the correct result of the simulation, however if you
[03:02:45] often see other project units terminating early like this
[03:02:45] too, you may wish to check the stability of your computer (issues
[03:02:45] such as high temperature, overclocking, etc.).
[03:02:45] Going to send back what have done.
[03:02:45] logfile size: 8531
[03:02:50] - Writing 9094 bytes of core data to disk...
[03:02:50] ... Done.
[03:03:00]
[03:03:00] [email protected] Core Shutdown: EARLY_UNIT_END
[03:03:13] CoreStatus = 72 (114)
[03:03:13] Sending work to server
[03:03:13] + Attempting to send results
[03:03:13] + Results successfully sent
[03:03:13] Thank you for your contribution to [email protected]
[03:03:41] - Preparing to get new work unit...
[03:03:41] + Attempting to get work packet
[03:03:41] - Connecting to assignment server
[03:03:44] - Successful: assigned to (171.65.103.150).
[03:03:44] + News From [email protected]: Welcome to [email protected]
[03:03:44] Loaded queue successfully.
[03:03:53] + Closed connections
[03:03:58]
[03:03:58] + Processing work unit
[03:03:58] Core required: FahCore_79.exe
[03:03:58] Core found.
[03:03:58] Working on Unit 07 [February 22 03:03:58]
[03:03:58] + Working ...
[03:04:00]
[03:04:00] *------------------------------*
[03:04:00] [email protected] Double Gromacs Core
[03:04:00] Version 1.72 (February 4, 2005)
[03:04:00]
[03:04:00] Preparing to commence simulation
[03:04:00] - Looking at optimizations...
[03:04:00] - Created dyn
[03:04:00] - Files status OK
[03:04:01] - Expanded 1238073 -> 4333817 (decompressed 350.0 percent)
[03:04:01] - Starting from initial work packet
[03:04:01]
[03:04:01] Project: 2391 (Run 1, Clone 23, Gen 3)
[03:04:01]
[03:04:01] Assembly optimizations on if available.
[03:04:01] Entering M.D.
[03:04:07] Protein: p2391_Ubiquitin_mutant
[03:04:07]
[03:04:07] Writing local files
[03:58:14] Extra SSE2 boost OK.
[03:58:54] Writing local files
[03:59:12] Completed 0 out of 500000 steps (0)
[04:00:21] Quit 101 - Fatal error: NaN detected: (ener[18])
[04:00:21]
[04:00:21] Simulation instability has been encountered. The run has entered a
[04:00:21] state from which no further progress can be made.
[04:00:21] This may be the correct result of the simulation, however if you
[04:00:21] often see other project units terminating early like this
[04:00:21] too, you may wish to check the stability of your computer (issues
[04:00:21] such as high temperature, overclocking, etc.).
[04:00:21] Going to send back what have done.
[04:00:21] logfile size: 8082
[04:00:21] - Writing 8645 bytes of core data to disk...
[04:00:21] ... Done.
[04:00:31]
[04:00:31] [email protected] Core Shutdown: EARLY_UNIT_END
[04:00:45] CoreStatus = 72 (114)
[04:00:45] Sending work to server
[04:00:45] + Attempting to send results
[04:00:46] + Results successfully sent
[04:00:46] Thank you for your contribution to [email protected]
[04:01:08] - Preparing to get new work unit...
[04:01:08] + Attempting to get work packet
[04:01:08] - Connecting to assignment server
[04:01:08] - Successful: assigned to (171.65.103.150).
[04:01:08] + News From [email protected]: Welcome to [email protected]
[04:01:08] Loaded queue successfully.
[04:01:15] + Closed connections
[04:01:20]
[04:01:20] + Processing work unit
[04:01:20] Core required: FahCore_78.exe
[04:01:20] Core found.
[04:01:20] Working on Unit 08 [February 22 04:01:20]
[04:01:20] + Working ...
[04:01:35]
[04:01:35] *------------------------------*
[04:01:35] [email protected] Gromacs Core
[04:01:35] Version 1.86 (August 28, 2005)
[04:01:35]
[04:01:35] Preparing to commence simulation
[04:01:35] - Looking at optimizations...
[04:01:35] - Created dyn
[04:01:35] - Files status OK
[04:02:31] - Expanded 726417 -> 3642037 (decompressed 501.3 percent)
[04:02:37] - Starting from initial work packet
[04:02:37]
[04:02:37] Project: 2370 (Run 2, Clone 61, Gen 7)
[04:02:37]
[04:03:28] Assembly optimizations on if available.
[04:03:28] Entering M.D.
[04:04:44] Protein: p2370_ADAh2
[04:04:44]
[04:04:49] Writing local files
[05:17:50] Extra SSE boost OK.
[05:18:00] Gromacs cannot continue further.
[05:18:00] Going to send back what have done.
[05:18:00] logfile size: 6477
[05:18:00] - Writing 7013 bytes of core data to disk...
[05:18:00] ... Done.
[05:18:07]
[05:18:07] [email protected] Core Shutdown: EARLY_UNIT_END
[05:18:18] CoreStatus = 72 (114)
[05:18:18] Sending work to server
[05:18:18] + Attempting to send results
[05:18:18] + Results successfully sent
[05:18:18] Thank you for your contribution to [email protected]
[05:18:30] - Preparing to get new work unit...
[05:18:30] + Attempting to get work packet
[05:18:30] - Connecting to assignment server
[05:18:31] - Successful: assigned to (171.65.103.150).
[05:18:31] + News From [email protected]: Welcome to [email protected]
[05:18:31] Loaded queue successfully.
[05:18:41] + Closed connections
[05:18:46]
[05:18:46] + Processing work unit
[05:18:46] Core required: FahCore_79.exe
[05:18:46] Core found.
[05:18:46] Working on Unit 09 [February 22 05:18:46]
[05:18:46] + Working ...
[05:18:53]
[05:18:53] *------------------------------*
[05:18:53] [email protected] Double Gromacs Core
[05:18:53] Version 1.72 (February 4, 2005)
[05:18:53]
[05:18:53] Preparing to commence simulation
[05:18:53] - Looking at optimizations...
[05:18:55] - Created dyn
[05:18:55] - Files status OK
[05:20:16] - Expanded 1351994 -> 4750197 (decompressed 351.3 percent)
[05:20:21] - Starting from initial work packet
[05:20:22]
[05:20:22] Project: 2355 (Run 0, Clone 161, Gen 2)
[05:20:22]
[05:21:29] Assembly optimizations on if available.
[05:21:29] Entering M.D.
[05:22:15] Protein: p2355_ADAh2
[05:22:15]
[05:22:22] Writing local files
[06:14:24] Extra SSE2 boost OK.
[06:15:06] Writing local files
[06:15:21] Completed 0 out of 500000 steps (0)
[06:19:06] Quit 101 - Fatal error: NaN detected: (ener[11])
[06:19:06]
[06:19:06] Simulation instability has been encountered. The run has entered a
[06:19:06] state from which no further progress can be made.
[06:19:06] This may be the correct result of the simulation, however if you
[06:19:06] often see other project units terminating early like this
[06:19:06] too, you may wish to check the stability of your computer (issues
[06:19:06] such as high temperature, overclocking, etc.).
[06:19:06] Going to send back what have done.
[06:19:06] logfile size: 8256
[06:19:06] - Writing 8819 bytes of core data to disk...
[06:19:11] ... Done.
[06:19:21]
[06:19:21] [email protected] Core Shutdown: EARLY_UNIT_END
[06:19:35] CoreStatus = 72 (114)
[06:19:35] Sending work to server
[06:19:35] + Attempting to send results
[06:19:35] + Results successfully sent
[06:19:35] Thank you for your contribution to [email protected]
[06:20:03] - Preparing to get new work unit...
[06:20:03] + Attempting to get work packet
[06:20:03] - Connecting to assignment server
[06:20:04] - Successful: assigned to (171.65.103.150).
[06:20:04] + News From [email protected]: Welcome to [email protected]
[06:20:04] Loaded queue successfully.
[06:20:15] + Closed connections
[06:20:20]
[06:20:20] + Processing work unit
[06:20:20] Core required: FahCore_79.exe
[06:20:20] Core found.
[06:20:20] Working on Unit 00 [February 22 06:20:20]
[06:20:20] + Working ...
[06:20:31]
[06:20:31] *------------------------------*
[06:20:31] [email protected] Double Gromacs Core
[06:20:31] Version 1.72 (February 4, 2005)
[06:20:31]
[06:20:31] Preparing to commence simulation
[06:20:31] - Looking at optimizations...
[06:20:31] - Created dyn
[06:20:31] - Files status OK
[06:21:48] - Expanded 1192959 -> 4140585 (decompressed 347.0 percent)
[06:21:53] - Starting from initial work packet
[06:21:53]
[06:21:53] Project: 2385 (Run 2, Clone 38, Gen 5)
[06:21:53]
[06:22:53] Assembly optimizations on if available.
[06:22:53] Entering M.D.
[06:23:37] Protein: p2385_ADAh2
[06:23:37]
[06:23:38] Writing local files
[07:10:14] Extra SSE2 boost OK.
[07:10:15] Writing local files
[07:10:15] Completed 0 out of 500000 steps (0)
There we go again. On a Gromacs core. I'm thinking I'm not completely stable, and since I'm also getting some frequent crashes in games, I'm suspecting my power supply, which isn't the greatest thing in the world.
So a pretty OT question. Will a digital multi-meter tell me for sure if the PSU is my problem or not? Or is it possible that it would show the rails completely stable, yet the PSU is still what's wrong. In other words, are their other factors besides rail voltages that make up a faulty PSU?
The multi meter should show fluctuations or an over or under volt situation but I am not sure if it will give the same readings as it would under a load and I don't know how to check one safely under load with a multi meter. When my oc was causing instability with folding I just cut it back from 2.6 to 2.4. I know that is a lot but I have had fewer problems and my cpu doesn't run as hot because I could ease up on the vcore. Veiwing your system specs, if it is your psu I would not buy another x-connect. I have seen a lot of bad reveiws on those. Try a sunbeem nuo or another highly recomended brand.
I know, I don't know what kind of illegal drugs I was on when I bought an Ultra PSU.
1 - 5 of 5 Posts
