Install Fibre channel drives in PC??
1026 12
Hey all,
I was just wondering if it's possible. I have a bunch of 15,000 2Gps fibre channel drives in racks at home but I was wondering if it's possible to install into a PC. Do they make a fibre channel card PCIX? Right now the racks and everything are at the house but i live in an apartment and Its too loud to have all 35 drives in their racks in my tiny apartment. I would really like to find a card that is PCI 8x or something but even an SATA to fibre adapter would work too. I don't need them for their speed i just need more space.
1 - 13 of 13 Posts
Discussion Starter · #6 ·
Those are only HBA Host bus adapters They only plug into the controller then the controller plugs into the racks which holds the hard drives. I guess they don't make any type of adapters. It sucks bc I have over 3TB in fibre channel drives and im out of space on my pc
Overclocking since 1998
Fibre Channel is the high end of the high end designed for large corporations. That means that Fibre Channel controllers are quite expensive if you're looking for a new one. The other difficult thing is that the connector on the Fibre host bus adapter will not plug directly into a drive. You will need an optical to SCA or a 2Gb copper to SCA adapter.
Your best bet would be the rack you have, which probably has a Fibre backplane in it. You just need to hook the host bus adapter up to the box.
1 - 13 of 13 Posts
