1 - 18 of 18 Posts
As title says I just installed my 580 and ran for about half hour then. Bang! Sparks come
Out of the power strip. I freak out and reach to unplug the pc from the strip only to realize that th cable is all burned and melted. So I threw out that psi cable and used another. Threwvaway power strip also. Booted up fine; temps are all good and all seems fine... has anyone got an idea wth happened?
Which wires exactly?
Just the power cable that attaches to the psi and an outlet. Internals are all fine.
Darn droid keeps making p s u say psi. Sry
Network Architect
Try it with a heavier gauge (thicker) PSU cable, I use one that is about as thick as my pinky finger
Preferably 18AWG
if it was 18AWG and melted (can find out on cable sleeve), then there is a problem elsewhere
Network Architect
Originally Posted by blackbalt89;15238447
You say you also threw out the power strip it was plugged into?
Could it be that the strip wasn't properly grounded or rated to push that much amperage?
Could be grounding issues, or poor power conditioning as well
Discussion Starter · #8 ·
Yes that was my first thauggt. It wa a cheaper strip. Said rated for 15 amps. I went from a 5850 to a 580 so I know itvis pushing more power.
Discussion Starter · #9 ·
Could something be causing grounding issues inside?
Network Architect
take the wall plate off of the outlet and make sure the ground wire (copper one) is connected properly, if not, cut the power and fix that
Discussion Starter · #11 ·
I will check. Due to the fact of my pc still functioning after that can I be someewhat sure that my p s u wasn't the culprit?
Kill the power *BEFORE* removing the wall plate unless you are an experienced AC electrician.
Discussion Starter · #13 ·
Yeah ground wire is all fine and dandy in there, ive been on the pc for an hour now, no problems as of yet. Can anyone recommend me a quality power strip surge protector?
Amazon.com: Belkin 12-Outlet Home/Office Surge Protector with Phone/Ethernet/Coaxial Protection and Extended Cord: Electronics
seems to have good ratings, and a fair price.
Check out their PureAV linup. Its basically the same, but conditions your power as well. You can often find the 12 outlet models on sale for around 50-60 (though retail is 120)
don't worry, all GTX580's let out sparks and fire in the beginning (it's part of the warm-up, break-in period)
mine was breathing fire, aka Fire-Dragon GTX580's (Skyrim Edition)
only joking
Discussion Starter · #18 ·
Well i went with an APC ups...875w battery backup, i needed to protect my investments haha!
1 - 18 of 18 Posts
