1 - 7 of 7 Posts
I just wanted to know where i could buy case lighting online, (one that can change through the color spectrum), and how to hook it up.
Read Only
As lame as it sounds, you may want to check out a local Best Buy or similar store, sometimes they will have random colored cathodes and whatnot for computers. They hook up via a small AC/DC converter thing, it just plugs into a molex connector from your power supply. Not sure where to get ones that change colors though...
Hi.
You can get CCFL (Cold Cathode Fluorescent Lighting... lol.. it's not "cold") from places such as:
Frozen CPU
Performance PC's
Directron
NewEgg
Lighting is generally powered viz the molex connectors, but some can be run off the motherboard headers.
nice guys will these lights hook up to the case lighting button on the haf x
Discussion Starter · #6 ·
Originally Posted by Syrillian
If they do not do so "out of the box", then a relatively easy modification will see that they do.
Maybe post pics of the lighting hook-up in your case?
alright i'll post pics when it arrives, (does it come lit up stock or is it just the fans?)
1 - 7 of 7 Posts
