Originally Posted by Xaimus
What exactly were the installation instructions?
RTL8180 Linux Driver version 1.4
- Support Client mode for either infrastructure or adhoc mode
- Support AP mode
RTL8180 Linux Driver version 1.5
- Turn on Dynamic Carrier Sense Function.
< Component >
The driver is composed of several parts:
(1)source code
driver module initialization and interface between rtl8180 driver and system call.
r8180_pci_init.c driver module initialization and register/unregister network device
r8180_pci_init.h include file
r8180_if.c interface between rtl8180 driver and system call
r8180_if.h include file
r8180_type.h type definition for rtl8180 driver
r8180_export.h exported function name from rtl8180 driver
(2)object code
rtl8180 driver
priv_part.o rtl8180 driver object code
(3)Default driver
rtl8180_24x.o default driver module compiled in kernel 2.4.18.
(4)Makefile
PLEASE SPECIFY INCLUDEPATH CORRECTLY ACCORDING TO YOUR LINUX ENVIRONMENT.
FOR EXAMPLE, " INCLUDEPATH=-I /usr/src/linux-2.4.18-3/include/ " in RedHat7.3.
FOR EXAMPLE, " INCLUDEPATH=-I /usr/src/linux-2.4.18-14/include/ " in RedHat8.0.
(5)wlanup/wlandown
simple script file to activate/shut_down wireless lan.
< Installation >
Please try to load linux_24x.o first by "insmod -f rtl8180_24x.o".
If it doesn't work, you are suggested to compile loadable driver module following the steps as:
(0)Make sure the C-compile version. Run "gcc -v".
If gcc version is 2.xx, use release driver RTL8180_24x_RH73.zip.
If gcc version is 3.xx, use release driver RTL8180_24x_RH90.zip.
(1)Modify macros in Makefile.
KERNELRELEASE - represent kernel release version
IO_FLAGS - pci I/O space mapping
ENDIAN_FLAGS - big/little endian
OP_MODE_FLAGS - Operation on either AP or Client mode
DRV_FLAGS - Driver debugging messge ...etc.
(2)Check pci module initialization and system call interfaces in the provided source code,
r8180_pci_init.c ....etc.
(3)Run 'make' to generate new driver module.
(4)Run 'make install' to install new driver module.
(5)Refer to < Set wireless lan MIBs > and modify script files,
wlanup/wlandown, to set Wireless LAN specific parameters.
Run wlanup/wlandown to activate/shut_down wireless lan.
Usage:
./wlanup {ap|infra|adhoc}
./wlandown
Note:
- "./wlanup ap" works if OP_MODE_FLAGS is assigned RTL_ACT_AS_AP in Makefile.
- "./wlanup {infra|adhoc}" works if OP_MODE_FLAGS is assigned RTL_ACT_AS_AP
in Makefile.
This driver uses Wireless Extension as an interface allowing you to set
Current driver supports "iwpriv", manipulate driver private ioctls, to set MIBs.
iwpriv wlan0 wlan_para [parameters]=[val]
where
parameter explaination [parameters] [val] constraints
Set beacon interval bcnint {20~1000} msec
Set channel number channel {1~14}
Set basic rates basicrates {bit0 = 1Mbps, bit1 = 2Mbps, bit2 = 5.5Mbps, bit3 = 11 Mbps}
Set operational rates oprates {bit0 = 1Mbps, bit1 = 2Mbps, bit2 = 5.5Mbps, bit3 = 11 Mbps}
Set authentication type authtype {opensystem, sharedkey, both<only AP mode>}
Set desired ssid to scan ssid2scan {0~z, less than 32 characters}
Set RTS threshold rtsthres {256~2304}
Set fragment threshold fragthres {256~2304}
Set preamble mode preamble {short,long,auto}
Set network type networktype {infra,adhoc,auto}
Set WEP mode wepmode {off,wep40,wep104}
Set WEP default key ID wepdkeyid {0~3}
Set 1st WEP40 key value wepkey40_1 {0~f, total 10 characters}
Set 2st WEP40 key value wepkey40_2 {0~f, total 10 characters}
Set 3st WEP40 key value wepkey40_3 {0~f, total 10 characters}
Set 4st WEP40 key value wepkey40_4 {0~f, total 10 characters}
Set 1st WEP104 key value wepkey104_1 {0~f, total 26 characters}
Set 2st WEP104 key value wepkey104_2 {0~f, total 26 characters}
Set 3st WEP104 key value wepkey104_3 {0~f, total 26 characters}
Set 4st WEP104 key value wepkey104_4 {0~f, total 26 characters}
Set AP ssid ssid {0~z, less than 32 characters}
Set Mac address macaddr {0~f, total 6 characters}
Set DTIM period dtimperiod {1~255}
Set hidden AP hiddenAP {true,false}
Set mac filter policy addmac {0~f, total 6 characters}
Delete mac filter policy delmac {0~f, total 6 characters}
Set deny mac filter policy denymacaddr {0~f, total 6 characters}
Delete deny mac filter deldenymacaddr {0~f, total 6 characters}
Set sta expired time expired_time {1~100000} *10 msec
Set rate adaptive autorate {true,false}
Print help message help
For example:
iwpriv wlan0 wlan_para bcnint=100
iwpriv wlan0 wlan_para channel=1
iwpriv wlan0 wlan_para basicrates=0xf
iwpriv wlan0 wlan_para oprates=0xf
iwpriv wlan0 wlan_para authtype=opensystem
iwpriv wlan0 wlan_para ssid2scan=testssid
iwpriv wlan0 wlan_para fragthres=512
iwpriv wlan0 wlan_para preamble=long
iwpriv wlan0 wlan_para wepmode=off
iwpriv wlan0 wlan_para wepdkeyid=0
iwpriv wlan0 wlan_para wepkey40_1=012
