installing on linux ubuntu
680 4
well install linux ubuntu on my computer finally, woohooo, [sorry that wasnt really needed] and now i need to install ac97 drivers and also a media player, i need some help i dont understand what it means i am completely lost with what i get when i click install. can anyone help me with this break it down or give me some easy ways in which i can do things.
if someone could help i will really appricate it.
thanks
1 - 5 of 5 Posts
ok.... For a media player, i would use AMARok...so...what you need to do...is get into the console. type
sudo apt-get update
sudo apt-get upgrade
sudo apt-get kde
sudo apt get kubuntu-desktop
sudo apt-get kde-core
sudo apt-get install amarok
as for the driver...do a google search.
the "sudo" command stands for "superuser do"
It will prompt you for the password and i think your username.
this is only required if you are not looged in as root, you can always open up the root console and omit the sudo command. I hope it helps....
huh? lol really when it comes to linux i aint the best person for it, i have red hat on another computer but i aint really looked at it, it is just on there, so i have no idea with the whole linux thing, i got the drivers but i have not the slightest on how to install them, i also would like to install wine tools and a media player, i am just really completely lost i need it to be broken down a little further for me
I don't know how to make it any more simple. I told you what to open and what to type. Go to system @ the top, click on console, and type the commands i told you to type....you'll have a fully fleshed out media player within a couple hours.
for some reason i need encoders for the mp3 files i have so atm i have no sound on this what so ever. i think i know how to install some things but having problems installing wine tools at the moment dont really understand the website, i am eagar to learn and i have been playing round now with linux for about 2 days, can anyone tell me how to get the sound encoders working or any other information i need to do to get the ubuntu to work.
1 - 5 of 5 Posts
