installing power supply to graphics card
264 Views 5 Replies 4 Participants Last post by  Evolutionsentra
Should the graphics card be directly powered from the PSU? With one of those 6 pin cables?
1 - 6 of 6 Posts
YES, or you rissk frying the card or damaging other components, or you wont see anything on the screen
They put it there for a reason
Am currently powering mine with one of those 4 pin connectos which are split.
Its the right cable on this pic http://www.bit-tech.net/content_imag...xfx-cables.jpg
Do I use this cable and plug in both ends or not?
Yep, that'll work fine if you don't have the direct plug from your power supply. Using 2 4pin molex connectors is the same thing, except you'll be sharing that line with anything else plugged onto it, obviously.
Is it better to directly plug it into the psu? I do have one of those cables
If you want your GPU to work properly, then make sure it's connected directly to the PSU.
1 - 6 of 6 Posts
