Installing Vista 64bit
287 Views 5 Replies 5 Participants Last post by  IamRolks
Am I supposed to do anything in the Bios?
There is this setting for 32bit and 64bit on my UD3R
I try to install Vista and it get's stuck on the blueish/greenish Vista wallpaper looking screen right after the little Vista bar that shows you that its loading..
I thought maybe it was a Bad Burn...But Idk. Or maybe it's normal for it to get stuck there for a bit?
1 - 6 of 6 Posts
stick the DVD in and boot from it, when asked... install and then enjoy your vista 64. you may need to change boot order to boot from DVD drive first.
yeah that's normal, just let it sit for a while, it takes some time, I think mine sat there for like 8-12 minutes before it even game me an option to start the install.
Yeah at certain points it can take a bit longer than others. Like the "Please wait" screen...But yeah you should be able to just pop it in and install.
Alright ty all.
Ima let it sit there and Ima spark up the Blunt. :>
1 - 6 of 6 Posts
