I'm going to be getting Vista soon and I just had a few questions.
I was wondering if there is a difference between "Upgrading" to vista or just uninstalling XP and installing vista. I'm getting Vista Ultimate but as you can see I know little about the difference between these options and if Windows Vista Ultimate even contains both options.
So my other noobs questions are...
If I were to "upgrade" to vista from XP, would my files/drivers/installed programs all pretty much remain the same?
If I were to uninstall XP and then install vista I assume I'd have to backup important files as they wouldn't be there after I install vista.. correct?
Thanks
Thanks
