1 - 8 of 8 Posts
So I have a 16gb usb drive configured to install windows 7 (from a legit iso). Problem is when I put it in a different computer that it wasn't configured on, it doesn't work. Is this supposed to happen? Can I fix it?
Thanks in advance
The Computer Guy
Just reformat the flash drive,that will fix it.(misread,sry.check 2nd post)
What program or method did you use to put the installation files on the USB stick?
The Computer Guy
Discussion Starter #8
I tried all of them. It does boot but I get some sort of boot error:
Windows failed to start. A recent hardware or software change might be the cause. To fix the problem:
1.blah blah blah
2.' '
3' '
If you do not have this disc, contact your system administrator or computer manufacturer for assistance.
File: \\Boot\\BCD
Status: 0xc000000e
Info: An error occurred while attempting to read the boot configuration data.
1 - 8 of 8 Posts
