order = cpu, vga, psu
you want your cpu to get the coolest water temps possible, which can only be achieved if it is first in the loop after the rad, in your case, reservator
now, with your psu, you are cooling it with water???? i am thinking you should stick with the fans....unless you wnat some hot water running through your system!
Originally Posted by mindracing I'm about to install my Reserator, CPU block, VGA block and water cooled PSU. Does it matter which order they are connected in? Is there an optimum order of flow? TIA |
