1 - 5 of 5 Posts
Hi
I have two intake fans at the bottom of my case. Problem is that infront of it there are no slits to suck the air. I always assumed that i sucked it from underneath the front USB ports. Anywayz the front part os the case is made from this perspex/plastic material. Any1 know of any tools that i could use to cut?
I've always wondered why cases have front fans like that with no air path?!? It might be better to get a side panel fan if you dont have one already...or do as you were and cut that front out a little..
dremel,and use i fine file or some sandpaper to take off the rough "burs" and make it smooth and nice lookin, then get some nice fan grills, and two fan filters for the intake fans...
1 - 5 of 5 Posts
