1 - 20 of 1,076 Posts
Discussion starter · #1 ·
I am requesting guys and gals to provide data to add with my own data.
Anybody with an Intel or AMD can enter, and for those of you with i7/xeon counterparts, please do a HT on and a HT OFF run.
GFLOPS WILL BE AVERAGED OUT
ANY CPU IS ACCEPTED
NO LinX, PERIOD. people who submit with LinX will get their submission declined until they re-run with IBT.
It must be in Intel Burn Test 2.5, TEN passes, 2GB of memory tested. (stress level HIGH)
IF YOU HAVE AN OLDER SYSTEM, and cannot use 2GB for the test, you may still submit and i will accept it.
You must show the IBT screen of your completed 10 passes plus your gflops, and you must have two cpu-z windows one showing your cpu info and one showing your RAM info.
Data will be collected and then put into the OP.
FASTEST CPU
hoss331: Intel Core i7 2600K @5.2GHz, RAM 2134MHz 7-10-7-27GFLOPS:140
HONORARY FASTEST CPU
NCspecV81: Intel Core i7 Extreme 980x @4.63GHz, RAM 2058 at 7-7-7-21GFLOPS:100
SLOWEST CPU
mott555: Intel Atom N270 @1.6GHz, RAM 532 at 4-4-4-12GFLOPS:0.39
mott555: Intel Pentium III E @801MHz, RAM 264 at 3-3-3-6GFLOPS:0.31
Core 2 Quad/Extreme/Xeon variant CPUs
mm67: Intel Core 2 Quad Q9550 @4.25GHz, RAM 1200MHz 5-5-5-15 GFLOPS:58
ghabhaducha: Intel Core 2 Quad Q9550 @4.0GHz, RAM 1000MHz 5-5-5-15 GFLOPS:54.3
srsparky32: Intel Core 2 Quad Q9550 @4.08GHz, RAM 1020MHz 5-5-5-15 GFLOPS:54
cryptedvick: Intel Core 2 Quad Q6600 @3.4GHz, RAM 850MHz 5-5-5-18 GFLOPS:43.7
pipnasty: Intel Core 2 Quad Q9550 @4.0GHz, RAM 942MHz 5-5-5-15 GFLOPS:53.5
rsfkevski: Intel Core 2 Quad Q9650 @ 4.0GHz, RAM 942MHz 5-7-7-18 GFLOPS:48
KingT: Intel Core 2 Quad Q9550 @ 3.9GHz, RAM 918MHz 5-5-5-15 GFLOPS:51
We Gone: Intel Core 2 Quad Q9550 @3.85GHz, RAM 1088MHz 5-5-5-15 GFLOPS:51
stevezer: Intel Xeon X3360 @3.65GHz, RAM 1032 at 5-5-5-18GFLOPS:49
PanicProne: Intel Core 2 Quad Q9550 @3.7GHz, RAM 1068MHz 5-5-5-15 GFLOPS:51.8
mattb2e: Intel Core 2 Quad Q9550 @3.78GHz, RAM 1068MHz 5-5-5-15 GFLOPS:51.8
fastsite: Intel Core 2 Extreme QX6700 @3.4GHz, RAM 826MHz 5-5-5-15 GFLOPS:43
this n00b again: Intel Core 2 Quad Q6600 @2.4GHz, RAM 1000MHz 5-7-7-19 GFLOPS:28
rx7i2: Intel Core 2 Quad Q9550 @3.5GHz, RAM 836MHz 5-5-5-15 GFLOPS:43
darookie: Intel Core 2 Quad Q9300 @3.5GHz, RAM 934MHz 5-5-5-15 GFLOPS:42
spiderm0nkey: Intel Core 2 Quad Q9400 @3.6GHz, RAM 1204MHz 9-9-9-24 GFLOPS:45.9
harobi: Intel Core 2 Quad Q6600 @3.5GHz, RAM 1036MHz 5-5-5-15 GFLOPS:38.9
alex-fitton: Intel Core 2 Quad Q6600 @3.2GHz, RAM 948MHz 6-8-8-22 GFLOPS:38.9
polska: Intel Core 2 Quad Q9550 @4.0GHz, RAM 942MHz 5-6-6-18 GFLOPS:52.2
jam3s: Intel Core 2 Quad Q6600 @3.2GHz, RAM 720MHz 4-4-4-12GFLOPS:37.3
Core i5/i7 SandyBridge CPUs
guerrilladawg: Intel Core i7 2600K HT OFF @4.5GHz, RAM 1600MHz 9-9-9-24GFLOPS:65
grishkathefool: Intel Core i5 2500 @3.8GHz, RAM 1600MHz 9-9-9-24 2T GFLOPS: 96.4883
this n00b again: Intel Core i5 2500K @4GHz, RAM 1600MHz 9-9-9-24GFLOPS:57.3
this n00b again: Intel Core i5 2500K @4.5GHz, RAM 1600MHz 9-9-9-24GFLOPS:63.3
jonesey17: Intel Core i7 2600K @5GHz, RAM 1600MHz 8-8-8-20GFLOPS:130.8
kyle2194: Intel Core i5 2500K @4.7GHz, RAM 1333MHz 9-9-9-24GFLOPS:115.7
lethalrise750: Intel Core i7 2600K (HT OFF) @4.8GHz, RAM 1600MHz 9-9-9-25GFLOPS:125.3
ballathefeared: Intel Core i5 2500K @5GHz, RAM 2154MHz 9-10-9-39GFLOPS:133.78
simpletech: Intel Core i7 2600K @5.2GHz, RAM 2132MHz 7-10-20-28GFLOPS:138.5
nagle3092: Intel Core i5 2500K @4.6GHz, RAM 1866MHz 8-8-8-24GFLOPS:120.9
koven: Intel Core i5 2500K @4.9GHz, RAM 2134MHz 9-11-9-28GFLOPS:70.9
tribeca: Intel Core i5 2500K @4.8GHz, RAM 1600MHz 9-9-9-24GFLOPS:123.3
munaim1: Intel Core i5 2500K @5.1GHz, RAM 1866MHz 8-9-8-24GFLOPS:135
jam3s: Intel Core i7 2600K @4.0GHz, RAM 1600MHz 9-9-9-24GFLOPS:84.4
Core i7/Xeon CPUs HT OFF
MrTooShort: Intel Core i7 Extreme 980x @4.5GHz, RAM 1602 at 7-7-7-20GFLOPS:97
Dorksterr: Intel Core i7 Extreme 980x @4.4GHz, RAM 2008 at 7-8-7-20GFLOPS:91.5
Bal3Wolf: Intel Core i7 930 @4.2GHz, RAM 1600MHz 7-8-7-21 GFLOPS:60
SgtHop: Intel Xeon W3520 @4.0GHz, RAM 1528 at 10-11-11-24GFLOPS:58
Riou: Intel Core i7 920 @4.0GHz, RAM 1526 at 7-8-7-20GFLOPS:56.8
Hendoproof: Intel Core i7 950 @3.83GHz, RAM 1668MHz 8-8-8-24 GFLOPS:55.5
Allensmart: Intel Core i7 930 @4.2GHz, RAM 1200MHz 8-8-8-23 GFLOPS:57.7
this n00b again: Intel Core i7 930 @4.2GHz, RAM 1524 at 7-8-7-24GFLOPS:59
ZealotKi11er: Intel Core i7 920 @4.4GHz, RAM 1678 at 8-8-8-24GFLOPS:56
radaja: Intel Core i7 920 @4.38GHz, RAM 1842 at 7-7-7-21GFLOPS:63.6
RyanB11: Intel Core i7 950 @4.5GHz, RAM 1720MHz 10-10-10-24 GFLOPS:65.4
WhiteDog: Intel Core i7 930 @4.5GHz, RAM 1288MHz 7-7-7-20 GFLOPS:62.8
radaja: Intel Core i7 920 @4.38GHz, RAM 1842 at 7-7-7-21GFLOPS:57
radaja (second submission): Intel Core i7 920 @4.5GHz, RAM 1714 at 7-7-7-21GFLOPS:65.8
2127: Intel Core i7 870 @4.0GHz, RAM 1530 at 9-9-9-24GFLOPS:54.8
unoe: Intel Core i7 950 @4.3GHz, RAM 1496 at 6-7-6-20GFLOPS:61
unoe: Intel Core i7 950 @4.2GHz, RAM 1464 at 6-7-6-20GFLOPS:59.8
H969: Intel Core i7 920 @4.3GHz, RAM 1640 at 8-8-8-24GFLOPS:62.6
tleiaxu ghola: Intel Core i7 930 @4.2GHz, RAM 1600 at 8-8-8-24GFLOPS:61.8
2010rig: Intel Core i7 930 @4.2GHz, RAM 1600 at 7-7-7-24GFLOPS:60
mm67: Intel Core i7 950 @4.1GHz, RAM 1800MHz 10-10-10-30 GFLOPS:60.1
mott555: Intel Core i7 CULV @1.2GHz, RAM 800MHz 6-6-6-15 GFLOPS:9.5
Core i7/Xeon CPUs HT ON
MrTooShort: Intel Core i7 Extreme 980x @4.4GHz, RAM 1600 at 7-7-7-20GFLOPS:92.3
supercynic: Intel Core i7 970 @4.0GHz, RAM 1284 at 8-8-8-20GFLOPS:80.2
Dorksterr: Intel Core i7 Extreme 980x @4.4GHz, RAM 2008 at 7-8-7-20GFLOPS:88
SgtHop: Intel Core i7 970 @4.4GHz, RAM 1056MHz 9-9-9-17 GFLOPS:79.3
aznofazns: Intel Core i7 970 @4.2GHz, RAM 1680 at 7-8-7-20GFLOPS:73
Bal3Wolf: Intel Core i7 930 @4.3GHz, RAM 1638MHz 6-8-6-21 GFLOPS:61
mm67: Intel Core i7 950 @4.1GHz, RAM 1800MHz 10-10-10-30 GFLOPS:52
SgtHop: Intel Xeon W3520 @4.0GHz, RAM 1528 at 10-11-11-24GFLOPS:54
this n00b again: Intel Core i7 930 @4.2GHz, RAM 1524 at 7-8-7-24GFLOPS:52.5
Riou: Intel Core i7 920 @4.0GHz, RAM 1526 at 7-8-7-20GFLOPS:51.2
ZealotKi11er: Intel Core i7 920 @4.4GHz, RAM 1678 at 8-8-8-24GFLOPS:57.6
rollinsounzboy: Intel Core i7 920 @4.1GHz, RAM 1596 at 8-8-8-24GFLOPS:56.9
radaja (2nd submission): Intel Core i7 920 @4.5GHz, RAM 1714 at 7-7-7-21GFLOPS:57
rubema: Intel Core i7 950 @4.3GHz, RAM 1496 at 8-8-8-24GFLOPS:54.9
flamin9 t00l: Intel Core i7 920 @4.2GHz, RAM 1600 at 7-8-7-20GFLOPS:58.7
2010rig: Intel Core i7 930 @4.2GHz, RAM 1600 at 7-7-7-24GFLOPS:57.2
Core i5 CPUs
Poisoner: Intel Core i5 760 @4.1GHz, RAM 1170MHz at 6-6-6-19GFLOPS:56.7
Riou: Intel Core i5 750 @3.8GHz, RAM 1522MHz at 8-8-8-24GFLOPS:52.3
jak3z: Intel Core i5 750 @4.0GHz, RAM 1604MHz at 6-8-6-24GFLOPS:55
Punceh: Intel Core i5 750 @3.53GHz, RAM 1606MHz at 8-8-8-24GFLOPS:50
djsi38t: Intel Core i5 750 @4.3GHz, RAM 2156MHz at 9-9-9-24GFLOPS:60.5
mtbiker033: Intel Core i5 750 @4.2GHz, RAM 1678MHz at 9-9-9-24GFLOPS:57.2
de cossatot: Intel Core i5 750 @4.2GHz, RAM 2108MHz at 7-10-8-26GFLOPS:59
dog5566: Intel Core i5 760 @3.96GHz, RAM 1584MHz at 7-8-7-20GFLOPS:57
jak3z: Intel Core i5 760 @4.3GHz, RAM 1640MHz at 8-8-8-24GFLOPS:61.07
tjbridge: Intel Core i5 760 @3.8GHz, RAM 1480MHz at 7-8-7-23GFLOPS:54.2
tjbridge: Intel Core i5 650 @4.6GHz, RAM 1616MHz at 7-9-7-24GFLOPS:30.9
MegaTesla: Intel Core i5 760 @4.3GHz, RAM 1680MHz at 8-8-8-24GFLOPS:61
retoric: Intel Core i5 760 @4.13GHz, RAM 1653MHz at 8-8-8-24GFLOPS:59.3
jenesuispasbavard: Intel Core i5 M 480 @2.8GHz, RAM 1066MHz at 7-7-7-20GFLOPS:20
Core i3 CPUs
TheOcelot: Intel Core i3 550 @4.18GHz, RAM 1715MHz at 7-7-7-24GFLOPS:26.6
sgthop: (Mobile CPU) Intel Core i3 M 350 @2.3GHz, RAM 1100MHz at 7-7-7-20GFLOPS:14.6
73110: Intel Core i3 530 @4.4GHz, RAM 1600MHz at 8-8-8-24GFLOPS:27.8
Core 2 Duo/Xeon variant CPUs
kora04:Intel Core 2 Duo E8500 @4.0GHz, RAM 850MHz at 5-4-4-12GFLOPS:24.7
Darius Silver:Intel Core 2 Duo E6750 @3.2GHz, RAM 1066MHz at 5-5-5-15GFLOPS:20.9
mm67:Intel Core 2 Duo E6300 @3.0GHz, RAM 860MHz at 5-5-5-16GFLOPS:19.6
tjbridge: (Mobile CPU) Intel Core 2 Duo T7250 @2.0GHz, RAM 664MHz at 5-5-5-15GFLOPS:8
jak3z: (Mobile CPU) Intel Core 2 Duo T9300 @2.7GHz, RAM 664MHz at 5-5-5-15GFLOPS:13.5
Intel Pentium CPUs
cyrious: Intel Pentium E5300 @3.3GHz, RAM 888 at 7-7-7-21GFLOPS:20
omari79: Intel Pentium E5300 @3.6GHz, RAM 800 at 5-4-4-13GFLOPS:23
cyrious: Intel Pentium M @1.9GHz, RAM 532 at 4-4-4-12GFLOPS:1.3
MR KROGOTH: Intel Pentium E2200 @3.1GHz, RAM 938 at 5-5-5-12GFLOPS:5.4
cyrious: Intel Pentium E5300 @2.98GHz, RAM 766 at 4-4-4-16GFLOPS:12
mm67: Intel Pentium E6500 @4.0GHz, RAM 800 at 5-5-5-18GFLOPS:24
menace: Intel Pentium D @3.6GHz, RAM 664 at 5-5-5-13GFLOPS:9.6
menace: Intel Pentium E5200 @3.46GHz, RAM 832 at 5-5-5-12GFLOPS:17
Intel Atom/Celeron CPUs
AMD Phenom I/II Dual/Tri/Quad Core CPUs
thrasherht: AMD Phenom IIx4 955 @ 3.8GHz RAM 900MHz 5-5-5-18GFLOPS:47
purduepilot: AMD Phenom IIx4 955 @ 3.8GHz RAM 900MHz 7-8-7-24GFLOPS:49
menace: AMD Phenom IIx4 940 @ 3.42GHz RAM 760MHz 5-5-5-18GFLOPS:34.3
menace: AMD Phenom Ix4 9850 @ 2.83GHz RAM 754MHz 5-5-5-15GFLOPS:27.5
Riskitall84: AMD Phenom IIx4 955 @ 4.2GHz RAM 1734MHz 7-7-7-20GFLOPS:55
Kasp1js: AMD Phenom IIx2 555 @ 4.12GHz RAM 1000MHz 5-5-5-18GFLOPS:26
caffienescandal: AMD Athlon II x3 unlocked to Phenom II x4 955 @ 3.45GHz RAM 1226MHz 8-8-7-20GFLOPS:39
Namwons: AMD Phenom IIx2 550 unlocked to Phenom IIx3 @ 3.9GHz RAM 1733MHz 9-9-9-24GFLOPS:39
ikem: AMD Phenom IIx4 920 @ 3.52GHz RAM 1008MHz 5-5-5-18GFLOPS:44
rictofen: AMD Phenom IIx3 720 unlocked to Phenom IIx4 @ 2.8GHz RAM 1608MHz 9-9-9-24GFLOPS:36.2
onoz: AMD Phenom IIx3 720 @ 3.5GHz RAM 1338MHz 9-9-9-24GFLOPS:34
metalbeersolid: AMD Phenom IIx4 955 @ 3.8GHz RAM 1342MHz 7-6-5-15GFLOPS:50
koven: AMD Phenom IIx4 955 @ 3.92GHz RAM 1492MHz 9-9-9-24GFLOPS:49.7
tmunn: AMD Phenom IIx4 955 @ 3.8GHz RAM 1066MHz 5-5-5-18GFLOPS:47.9
sendblink23: AMD Phenom IIx4 965 @ 4.02GHz RAM 1301MHz 7-7-7-20GFLOPS:52.2
razrm3: AMD Phenom IIx4 955 @ 3.72GHz RAM 1333 8-8-8-21GFLOPS:48.7
freakn: AMD Phenom IIx4 955 @ 3.8GHz RAM 1600MHz 8-8-8-24GFLOPS:47.1
Phoenixlight: AMD Phenom IIx4 965 @ 3.6GHz RAM 1336MHz 9-9-9-24GFLOPS:44.4
AMD Phenom II hexcore CPUs
sleepergsr: AMD Phenom IIx6 1090T @ 4.3GHz RAM 1814MHz 7-8-7-21GFLOPS:82.5
antuk15: AMD Phenom IIx6 1075T @ 4.1GHz RAM 1566MHz 9-9-9-24GFLOPS:77.1
chucklc: AMD Phenom IIx6 1090T @ 4.0GHz RAM 1446MHz 8-8-8-21GFLOPS:76
decimate: AMD Phenom IIx6 1090T @ 4.0GHz RAM 1814MHz 6-8-6-20GFLOPS:76.3
wheth4400: AMD Phenom IIx6 1090T @ 4.0GHz RAM 1814MHz 6-8-6-24GFLOPS:73.9
Penryn: AMD Phenom IIx6 1055T @ 3.9GHz RAM 1500MHz 9-9-9-24GFLOPS:72
alienguts: AMD Phenom IIx6 1055T @ 4.0GHz RAM 1336MHz 7-7-7-24GFLOPS:75
coopa88: AMD Phenom IIx6 1090T @ 4.0GHz RAM 1672MHz 9-9-9-24GFLOPS:76.9
IOSEFINI: AMD Phenom IIx6 1090T @ 4.3GHz RAM 1918MHz 7-7-7-21GFLOPS:83
de cossatot: AMD Phenom IIx6 1090T @ 4.1GHz RAM 1532MHz 7-7-7-24GFLOPS:75
eclipseaudio04: AMD Phenom IIx6 1055T @ 4.0GHz RAM 1706MHz 6-8-7-22GFLOPS:77.9
philbrizo: AMD Phenom IIx6 1090T @ 3.9GHz RAM 1652MHz 9-8-8-18GFLOPS:74.6
Artikbot: AMD Phenom IIx6 1055T @ 3.5GHz RAM 1672MHz 6-7-6-21GFLOPS:67
plagueis: AMD Phenom IIx6 1090T @ 4.3GHz RAM 1310MHz 7-8-7-21GFLOPS:80
the.hollow: AMD Phenom IIx6 1090T @ 3.8GHz RAM 1600MHz 7-8-7-22GFLOPS:72.3
AMD Turions/Opterons/Semprons
reflex99: AMD Turion x2 RM-70 @ 2.0GHz RAM 666MHz 5-5-5-15GFLOPS:6.3
Crabid: AMD Turion 64x2 Mobile TL-50 @ 1.6GHz RAM 534MHz 4-4-4-12GFLOPS:1.4
AMD Athlon Duals/Tri's
Menace: AMD Athlon IIx3 440 @ 3.4GHz RAM 758MHz 5-5-5-15GFLOPS:25
Menace: AMD Athlon 7450 @ 3.0GHz RAM 666MHz 4-4-4-12GFLOPS:15
Cyrious: AMD Athlon 64x2 3800+ @2.0GHz RAM 200MHz 3-4-2-8GFLOPS:5
420Assassin: AMD Athlon 64x2 3800+ @2.7GHz RAM 392MHz 3-2-5-7GFLOPS:8.5
AMD Athlon Quads
pioneerisloud: AMD Athlon IIx4 630 @ 3.7GHz RAM 1100MHz 5-5-5-15GFLOPS:45.3
linkin93: AMD Athlon IIx4 635 @ 3.6GHz RAM 1666MHz 9-9-9-24GFLOPS:43.3
terence52: AMD Athlon IIx4 620 @ 3.6GHz RAM 1504MHz 6-7-6-21GFLOPS:47.5
this n00b again: AMD Athlon IIx4 630 @ 2.8GHz RAM 1338MHz 9-9-9-24GFLOPS:34
jacka: AMD Athlon IIx4 620 @ 2.6GHz RAM 800MHz 5-5-5-18GFLOPS:31.59
this n00b again: AMD Athlon IIx4 620 @ 3.5GHz RAM 1333MHz 9-9-9-24GFLOPS:40
In for Stress test goodness.
Edit:
Updated to 7-8-7-21 timings, got 2 more GFLops.
Up to 3.96Ghz, Interesting results:
Reactions: srsparky32
Discussion starter · #4 ·
Originally Posted by rsfkevski View Post
I'd like to contribute my Q9650 @ 4.05ghz, but I'm going to have to figure out how to get 2048GB of Ram free to be able to do the test on High...LOL
I'll get it figured out, just give me some time...gotta go through and "end process"
lol, that would work, and putting it on high will allocate 2GB. just close all programs except for IBT.
I didn't mean just C2Q and i7, this should be open to all processors. Anyone who wants to provide data.
I think I'm even going to bust out one of my old P4 systems for comparison.
Heres my i7 at 4200mhz ram at 1600mhz going to run the ht one for you also will edit this when i got it done.
Ok heres 4200mhz with ht on my 24/7s settings id run 4300 but it gets toasty with ht on.
Here's with HT on, W3520, 4011MHz, 4/8, 1528, 10-11-11-24 (Really loose, apparently.), average of 54.3574.
And, HT off, W3520, 4011MHz, 4/4, 1528MHz, 10-11-11-24, avg 58.0741.
I'll get the 10 runs here in a bit. Don't feel like shutting everything down right now, lol.
http://img833.imageshack.us/img833/1...ghz10runsr.png
Here is my Q9550 @3.9GHz in IBT 10 runs with max available RAM (3.5GB of 4GB total)
2x2GB PC2 8500 RAM @ 918MHz CL5,PL=10 in DC
P45 Chipset..
IBT/Linx Gflops results shouldn't be taken as valid comparesment due inconsistent Gflops results between two runs without obvious reason and especially in Linx due variable of problem's size that's being calculated..
CHEERS..
Discussion starter · #15 ·
P45 Chipset..
CHEERS..
dude quit bashing IBT. k? the scores are close enough. I average them out anyway.
and the requirement is 2GB used not 3.5
you also forgot to list your RAM timings in a seperate CPU-Z screen.
24/7 Use
No HT
Stock
Edit:
Just read the rules, running it on high 10 runs right now.
http://img225.imageshack.us/img225/3...10runs3901.png
Here is my Q9550 @3.9GHz in IBT 10 runs with dedicated 2GB of 4GB total RAM
P45 Chipset..
I don't have time to rerun IBT with CPU-Z timings tab open but timings are 5-5-5-15 and Performance level = 10 @ 918MHz RAM (459MHz FSB x 2)..
If you wanna ad my score do it,if don't then don't..
You see that I have the same score as you even I run 100MHz less CPU,12MHz less on FSB freq and over 20MHz less on RAM freq..(That can't be only by running @ lower timings)
CHEERS..
