1 - 15 of 15 Posts
hello im am building an intel c2d pc and i have a slite problem the mobo im getting is the: Asus P5NSLI, nForce-570 SLI <a href="http://www.komplett.co.uk/k/ki.asp?sku=324426" target="_blank">http://www.komplett.co.uk/k/ki.asp?sku=324426</a><br />
and it says it only supports PC2-4300, PC2-5300 ram types<br />
now its a wee bit hard to fined good ram at low prices for pc5300<br />
i was wondering if i would be able to use pc5400 in the slots<br />
the reson im thinking i can is because on the komplett site they have included corshair pc5400 in the pc5300 section<br />
<br />
i could live with getting pc5300 but i realy did want corshiar<br />
also if i cant fit the pc5400 wich of these would be better:<br />
<a href="http://www.komplett.co.uk/k/ki.asp?sku=321129" target="_blank">http://www.komplett.co.uk/k/ki.asp?sku=321129</a><br />
or<br />
<a href="http://www.komplett.co.uk/k/ki.asp?sku=327536" target="_blank">http://www.komplett.co.uk/k/ki.asp?sku=327536</a><br />
<br />
may main reson for asking is that both of these run on 2.2v but for sam dam dumb ass reson thaqt board only goes to 2.1v (if my reading is correct)<br />
<br />
just for the sake of it heres the rest of my specs:<br />
c2d e6300 ( i plan to oc this to around 2.4 -2.6 if poss)<br />
zalman 9500<br />
7900 gto (plan to oc to gtx speeds or close)<br />
hyper type r 580w psu<br />
my cooling will include 2x 12cm fans and 1 9cm ram mounted on the side or my thermaltake saprano<br />
<br />
ty for any help givin i tryed thinking and reading around but i couldnt come to a conclustion so i thought y not ask the guys that know these things<br />
also sorrie for posting this here but thers not ram sections<br />
<br />
(spelling mistakes? sorry....lmao)
not going to OC with an nvidia chipset...<br />
<br />
and there are <a href="http://www.overclock.net/intel-memory/" target="_blank">Intel</a> and AMD memory sections..
*nods* The P5NSLI has a max fsb of 330...which is poopy. Get sthe P5N32-SLI Premium. It is expensive but has the 590SLI
Discussion Starter #4
humm i was thinking that my self but..<br />
its not a huge overclock like 600mhz the board comes with oc'ing programs and bios will oc at 1mhz increasments<br />
<br />
like i said i know when it gets to big oc'ing its very important about chipset ect ect<br />
<br />
but i would have thought that it wouldnt hold me back that much as my oc will be small
are you even planning on going SLI with that 7900? if not, you can just get a board with an intel chipset. Heck, you can run SLi on those boards with hacked drivers, and eventually normal drivers.<br />
<a href="http://www.tbreak.com/forums/showthread.php?p=266475" target="_blank">http://www.tbreak.com/forums/showthread.php?p=266475</a> <--quad sli.
Discussion Starter #6
cgrado<br />
<br />
i was getting the sli to be some what future proff the 7900 will run most games as u know but in a few years ill be f**ked<br />
<br />
im in a tite spot will a grand budget for now im 15 ill be working in 2 years so ill be able to but a nice shiney gfx card every few months but till then i have to ask my mum for parts and she doesnt see how important a better gfx card is so my chances of an upgrade wil be low<br />
<br />
on the other hand if i plan to sli the gto's ill have to by the second soo and i cant lol (budget) so by the time i can afford a new gto they will be all gone unless they start making them permenant beacuse of the boom<br />
<br />
plusi love nvidia and iv had a few people tell me that nvdias arnt for intel boards but i want a e6300 lol so when i seen this mobo i was like woooot ;P<br />
<br />
would u recommend me getting a singal slot pci-e mobo?<br />
i have around 80 pound to spend on the mobo...<br />
<br />
bah im soooo confused <img src="/images/smilies/frown.gif" border="0" alt="" title="Frown" class="inlineimg" />
No, most boards aren't single slot pci-e, (the ones that are are crap) but i think you can get a good p965 chipset and OC that 6300 to over 3.0ghz with good cooling. With hacked drivers, you should still be able to run SLi with two 7900s when the time comes. Although G80 is right around the corner, you obviously can't afford it, so i guess waiting to go SLi is right for you. you may not have DX10, but they aren't too shabby of a setup. <img src="/images/smilies/thumb.gif" border="0" alt="" title="Thumb" class="inlineimg" /> <br />
<br />
My favorite board- the Asus P5B-deluxe(965P)<br />
Other boards- Asus P5WDH (expensive, 975X)<br />
<br />
<br />
<br />
(btw i'm 15 too, i'm up late doing my english paper, just finished. )
Discussion Starter #8
humm you see my problem is i have lloked round and round trying to get the best preformance for the buck<br />
and will all my parts atm im at like 989 pounds and i still need good thermal paste...<br />
so things are a wee bit tite<br />
atm heres all my parts along with ther price<br />
<br />
prossesor 125<br />
mobo 79<br />
mouse 33<br />
gfx card 206/181 ?<br />
ram 175<br />
headset 27<br />
case 50<br />
psu 63<br />
p and p 42<br />
hd 43<br />
lcd screen 141<br />
cpu cooler 32
hm.. what site are you using so i can see what i can find?<br />
Think you can stretch your budget for <a href="http://komplett.co.uk/k/ki.asp?sku=323507&view=detailed" target="_blank">this</a>?<br />
<a href="http://www.savastore.com/productinfo/product.aspx?catalog_name=Savastore&product_id=10293044&pid=45&tid=2" target="_blank">cheaper</a>
Discussion Starter #10
site (s) <img src="/images/smilies/tongue.gif" border="0" alt="" title="Stick out tounge caps" class="inlineimg" /><br />
<a href="http://www.overclockers.co.uk" target="_blank">www.overclockers.co.uk</a><br />
<a href="http://www.komplett.co.uk" target="_blank">www.komplett.co.uk</a><br />
<a href="http://www.thecoolingshop.com" target="_blank">www.thecoolingshop.com</a> (this is just for case and psu)<br />
<br />
ty btw dude do u play cs:s ill have to own u for your help if you do even tho my piece of scrap only runs it at 40 fps atm <img src="/images/smilies/tongue.gif" border="0" alt="" title="Stick out tounge caps" class="inlineimg" /><br />
<br />
and dude iv only been oc'ing for a few weeks so flashing and all the rest is basicly no mans land for me atm
nope, i play BF2. not CS:S. well, i need some sleep (4 hours!) so goodnight, i'll talk again later today.
P5B deluxe is an expensive motherboard. GO with a Ga-965P-S3 and you wont be disappointed.
Discussion Starter #13
link plz?
Discussion Starter #14
problem solved !!! <img src="/images/smilies/tongue.gif" border="0" alt="" title="Stick out tounge caps" class="inlineimg" /><br />
grand total 1016 pound (16 pound dam ill cut the grass or somthing)<br />
<br />
how did i fix it with these 2 :<br />
<br />
G.Skill 2GB DDR2 NR PC2-6400 (2x1GB) CAS5<br />
<a href="http://www.komplett.co.uk/k/ki.asp?sku=323507&view=detailed" target="_blank">http://www.komplett.co.uk/k/ki.asp?s...&view=detailed</a><br />
<br />
dont tell me not to get cas5 ill drop kick u for breaking my joy!!!! <img src="/images/smilies/tongue.gif" border="0" alt="" title="Stick out tounge caps" class="inlineimg" />
<a href="http://www.gigabyte.com.tw/Products/Motherboard/Products_Overview.aspx?ProductID=2321&ModelName=GA-965P-S3" target="_blank">http://www.gigabyte.com.tw/Products/...ame=GA-965P-S3</a><br />
<br />
This is the price/perf king.<br />
<br />
Overclockers.uk hav it for 74 quid.
1 - 15 of 15 Posts
