1 - 11 of 11 Posts
Hie guys..just wondering..is celeron d good enough to overclock?coz i;m using 1..and thinking of overclocking..thanks for any replies!..<img alt="" class="inlineimg" src="/images/smilies/redface.gif" style="border:0px solid;" title="Embarrassment">
Anything is good enough to overclock. Give it a shot!
Some of them (65nm ones) overclock like crazy! Not sure about your motherboard though...
Discussion Starter #4
but then..what the safe temp?or how high should i go?
Is it a presscott? If so, stay under 60C.<br />
<br />
Go as high as the sky, or until you're temperature gets to 60C.
Administrator
The 65NM Celerons D's are great overclockers and get some stupid speeds. <br />
<br />
However it being the Prescott core its still known to get toasty even with a 65nm fabrication and with High overclocks so you will want to consider getting a good cooler also.
Discussion Starter #7
thanks..i give it a shot...
Discussion Starter #8
hmm...maybe then i won't oc 1st..wait until i get a better cooler..rite?
<a href="http://www.frozencpu.com" target="_blank">www.frozencpu.com</a> has the best air cooler being sold now on the first page. Look for the "Tuniq Tower 120". Hurry, there's only a few left in stock and make sure your motherboard is compatible with it.
Discussion Starter #10
thanks!..i check it out...
I had a crazy one - 2.66 that ran at 3.7 full-time on stock cooler.<br />
<br />
For showing off I could clock it up to 4+ but the stock cooler was definately letting it down. Only ran for an hour or so under full load before bombing out.<br />
<br />
That chip still holds my personal superPI record. I miss it.
1 - 11 of 11 Posts
