2721 - 2740 of 2781 Posts
OC...D
Found one 10980XE open box for 830€ locally and grabbed it, late to the party eh. Still running 7980XE and W-3175X on main rigs. Got Rampage VI Apex and Corsair 4000 32GB kit to play with the 10980XE on water, hope it works. Could've gone for AMD also but was kinda looking for this CPU for a long time but didn't feel like buying with the standard price.
Any issues with the Apex with this CPU?
None. As mentioned, you gotta fan cool the VRMs on the Apex with the `0980 or 7980Xe.
Reactions: xarot
Strange that you get a warning for anything above 1.7 VCCIN. Mine won’t run when it droops to much below 1.7. Mine is set to 1.85 amd LLC of 4 and under heavy load droops to just above 1.7. I set it to 1.8 with same LLC and it will drop below 1.7 and sometimes result in a WHEA BSOD. I don’t like running my LLC to high as it overshoots and oscillates before settling out then overshoots even more when removing load.
lol thats odd i run 2.1 vccin on all of my 2066 chips
Old and Decrepit
you shouldnt have issues with a fan on the vrms. with a fan on the vrms they should top out in the low 80s roughly
80s area bit toasty for me. I put a separate water block on the R6E because of it and the VRMS never topped 40. With the factory hunk of metal on the R6EE mid 50s. First Gen VRMs and cooling left a bit to be desired.
The encore with 5.1ghz 10980 overclock still never push my stock cooled vrms above 50c. I think they do not need water cooling. This is also with a super low fan profile at 500 rpm or so on case fans and quiet mode on vrm fans.
Old and Decrepit
There’s a MASSIVE difference between an Omega and Encore compared to the original extreme and apex.
Post up that 5.1 over in the 5GHz OC club.
Does it need to be all core ? I have 5.1x2 5.0x4 4.9x8 and 4.8x18.
Edit: Not needed I saw. This is my 24/7 setup and when gaming the hottest core does not even reach 68c. Cpuz stresstest and hottest core 84c. This is with ambient 24c and water 25c. Techn block. 200l/h flow.
That club is so overrated. I think the way they set the requirement means all modern Intel chip will be able to achieve it. I got this long time ago but never post it there.
I just buldoze thru 5 GHz for few seconds. In fact my chip throttle like mad but this is 5 GHz all cores.
Old and Decrepit
Same requirements as how many cores etc as HWBOT.
I got 5.1 but I run at least a round of cinebench or I don't count it. Some of the others its tough to beat When they have engineering samples on LN2 to get 5.9. Yeah I can jack mine to probably 5.4 long enough to run the CPUZ but whats the point in that. I can stay out of the throttle zone at 5.1 and actually run something other than CPUZ.
Old and Decrepit
I think we crossed wires here sometime. The thread is 5GHz all cores. Pulling off 5.1 on two is easily done. I’m a bit confused as your core count is a bit more than 18. My highest posted is 5.1 all cores. I’m having difficulty understanding 25C liquid temp on a 24 C ambient and 68C at 4.8 can you post up a 30 minute Cinebemch 23 run with HWinfo up showing core speeds, vid and core temps? I’ve got an overkill loop and can’t touch 68C with all cores at 4.7 1.185Vcore and 22 C ambient.
I think we crossed wires here sometime. The thread is 5Hz all cores. Pulling off 5.1 on two is easily done. I’m a bit confused as your core count is a bit more than 18. My highest posted is 5.1 all cores. I’m having difficulty understanding 25C liquid temp on a 24 C ambient and 68C at 4.8 can you post up a 30 minute Cinebemch 23 run with HWinfo up showing core speeds, vid and core temps? I’ve got an overkill loop and can’t touch 68C with all cores at 4.7 1.185Vcore and 22 C ambient.
I'd be curious to see this as well. I am running all cores at 4.7 with 1.18V and I'm at 71C with 19C ambient temps using 3 360s and a signature V2.
Old and Decrepit
Yeah same boat here. I can run up or down but all [email protected] 1.185V and I’m hitting mid 70s with a 24C ambient with 600L/hr flow through an Optimus foundation ATM (which BTW is about a perfect mimic of the Signature V2) GTR 420, GTS 360, 480XE and 360SE and liquid temp is never 1C above ambient, like ever...maybe when I first turn it on but my fan profiles keep it under 30 which is for the most part VERY good with 600W of load on it. Even if I open aqua suite and crank all the fans to full bore on Noctua 2000 rpm industrial fans it may stay around 28C. Run something that pushes my GPUS as well and all that goes out the window and 30-31C with everything running full tilt. If I open the window behind the PC and drop the ambient I end up lower 70s under load but never 60s at 4.7 much less some at 4.8 and 2 at 5.1. I’d be lucky to stay in the 80s on the cores at or above 4.8, when I ran all cores to 5.1 I was in the low 90s for CB23 and high 90s for Blender quick with an AVX offset of 1 so really 5GHz on that one. I’ll be expecting to see loop temps drop when I finish up the MORA and put that sucker in the window but that’s more like an ambient of 0-5C at that point. Winter time chiller.
I’d like to know the secret weapon.
5GHz submission club submission.
Oh wow, what is your SP?
Also how do you like the Techn block? Review for AMD is better than Optimus Signature v2 but I see there are lots of cosmetics issue like nickel flaking and microchannel bending?
Tested my 10980XE on air last night (NH-D15) and some quick CB runs only.
4.5 - 4.7 GHz - CB run at 1.165V (Didn't test any lower either)
4.8 GHz - CB run at 1.22V
5.0 - Windows 1.26V
5.1 - Windows 1.3V (CPU-Z validation BSOD - stopped here)
5.2 - Might be possible with cold water?
Average chip I guess, but impressive still. My 7980XE won't run CB stable above 4.6 on R6E, but could be R6E power limitations kicking in. Maybe 4.6~4.7 GHz is fine with 10980XE on water. With all the SK-X chips I've had so far, the things start to get toasty after 1.18~1.2V if I'm hammering them with stress testing. The highest multiplier possible on air/water and just booting into Windows usually has given me a good education of the chip's capabilities. So comparing 10980XE 5.1 bootable for example to my 9900X that couldn't boot to Windows at any voltage at 4.7 GHz.
5.0 - Windows 1.26V
I believe 4.7- 4.8GHz will be no issue on water for that new chip. Pretty typical 10980xe from what I've seen around here. Mine does 4.7GHz 1.15v on the Apex.
Reactions: xarot
Old and Decrepit
Yeah 4.7-4.8 is about the average that doesn’t start getting hot, can keep it under 80C. 4.9 is knocking on 80-85. That jump to 5GHz and up takes some juice. I can run 4.7 at 1.85 and stable as a rock and 4.8 at 1.235. 4.9 at 1.265 then 5 takes 1.3 and 5.1 1.136 and knocking on the door of 100C.
Ok what's the test and software you want me to run ? Please describe. I have an average chip so either I am not doing it right or something else plays in here.
45 min CPUz stresstest 100% usage. Again gaming never over 65c on these clocks.
I lowered max core to 4.9 as on 5.1 I need 1.365 which is a bit too much in my taste thinking about it. 5.0 is 1.351 so the step to 4.9 as in the pictures feels better.
Edit: I think I found the misunderstanding. I said "This is my 24/7 setup and when gaming the hottest core does not even reach 68c. Cpuz stresstest and hottest core 84c. This is with ambient 24c and water 25c "
Not that hottest core in a stress test is 68. Then I need to have open window and lower ambient of course.
My radiators are 3360 airplex gigant and 4x360, 1x240. Quad d5 pumps.
I examined the block, no microchannel bendings or issues. I think it has solid quality.
