2861 - 2880 of 2915 Posts
Found it ...
... ran it.
"Of errors is not detected"
2488290
*Note to self. Get GSAT USB working.
I guess we will need to refer to this at some point ...
2488292
OC...D
Dropping ram voltage introduced a cold boot error, qcode stuck at detecting RAM. Pushed back to 1.4, all good again. Sadly this BIOS does not appear to have DRAM boot voltage.
I'll go digging for TMS.
LLC was AUTO, reporting 7. I have now set to that value in BIOS
set CPU Current to 200 or in that range
Disable VRM Spreadspectrum
CPU power phase to Optimum or Extreme
POst up a bios SS of the other key bios pages...
OC...D
Ya really do no
Found it ...
... ran it.
Ya really do not need a gsat USB. Google Windows Bash. Follow the instructions to enable the Linux Ubuntu Shell. You can easily run GSAT with that. It works fine.
TM5 really requires a diff config file (and needs to be run as Admin. It's a good program, but it should run 10-12 cycles for good coverage.
GSAT is a 1 hour run and the report on any errors helps to define the type.
OC...D
yep, there's a fair about we can do with those timings. 1.45V is a safe (very safe) level for B-die. Keeping the sticks below 40C during stability testing is critical - normal use will not usually get that hot.
Here's where I have 64GB tuned to as a rough guide with 1.43V. Ignore the RTLs, just leave yours on Auto.
OC...D
I'll check back tomorrow evening...
Google stress app running in windows.
For anyone else, I used this guide:
and this
Once I had the ubuntu "command line" up and running (and stopped saying THAT line from Jurasic Park) - I used the following commands:
sudo apt update [i think this updates the app store]
sudo apt install gcc [this installed something]
sudo apt install stressapptest [this installed the google memory test tool]
To run the tool i used:
stressapptest -W -M 26624 -s 3600 --pause_delay 3700
stressapptest -W -M 26624 -s 1800 --pause_delay 1900
*Note, this was edited to add the --pause_delay.
Reactions: sultanofswing
OC...D
By defining the ceiling of ram used windows avoids choking. The program will test all installed ram. For 32GB use the following command:
once it completes (without errors) the window will look like this. There's no need to stop the run if an error occurs, and the report defines whether it is a CPU or a specific dram error.
2488441
OK, i'll kick that off now. Nice to see you using SIV.
Tick. Pass.
2488448
OC...D
damn - I can't open that pic. can you post it using the picture insert tool in the editor menu?
2488466
2488467
This!
Will be going here!
2488468
And the drawer will go here!
2488469
Table made from rare teak wood. Planned this for few months finally almost finished. Supposed to post once finished but I can’t wait to show off. Lol!
Will be running 10980XE at 5 GHz all core adaptive and prime 95 stable. Will try 5.1 but may require delid or at least liquid metal on top of IHS. Cache between 31 or 32 still can’t decide because 31 only needs +0.2v offset while 32 needs whooping +0.375v offset.
What do you guys think of liquid metal between IHS and cooler? The water block is EK Velocity sanded to match the IHS contour. So it is now bare copper after sanded. I don’t mind the stain on the waterblock but how about IHS? Heard specifically conductonaut will not stain IHS that bad?
The IHS is sanded very very slightly only on the 4 corner because it is sharp and leaving mark on my wb which means they are protruding.
Thanks for those tutorials on getting GSAT working in Windows, Was able to get it running tonight and passed with my current settings. Tomorrow I am going to up my cache back to 32 and 1.2v and see if that passes.
OC...D
Hmmmm, i used that, let me try again. Will add as attachment too.
Yep, the thumbnail worked! So if you want to try to fine tune further, post up a SS of asrock timing config and let's have a go! (y)
Right then, brace brace brace ...
2488539
OC...D
lol - let's start with a few small steps.
First - SAVE your current OC to a save slot or USB. Clrcmos (if you loaded XMP at anytime since the last clrcmos there are settings in place you can't change from within bios) , enter bios, load your saved OC, if it is an XMP OC, load optimzed defaults and reboot, manually enter the cpu OC, do not load XMP!
There are several "paths" here's 3:
A)
Load the timings I posted earlier for 3733c15 - all except RTLs. Dram Clock = 10. Enter 1.45V VDIMM. Set cache back to auto multi and voltage. Leave Uncore offset at +0.400. Dram speed to 3600. If it posts we are off to the races! (3600C15 IS WAY FASTER THAN 3733C18.)
B)
ClrCmos. POST to bios.
Nav to the dram timings and manually enter the Primary timings I posted for 3733c15 15, 15,15, 36 2. (leave RTLs and IOLs and everything else on auto)
VDIMM to 1.45
Dram Freq to 3600
cache multi and voltage to Auto
F10 to save and exit
If it posts do a quick 5 min (300 sec) GSAT test.
C)
1.45V VDIMM, Leave everything as you have it for GSAT stable 3733c18
Lower CAS until it fails POST (the training routine is fairly robust). Q-code BD is the likely error the bios would stall on. If that happens, ClrCmos and reload the OC you saved. Find the lowest CAS value that will post at 1.45V
If you go route C, post back with the min CAS that will post and train to RTLs no more than 2 difference between the channels (eg, like the 61,63,61,63 you posted above)
Reactions: PipJones
OC...D
Lol - That link is to Silent_scone's OCUK thread. He also started a ram thread here
OC...D
GSAT is the "final say" on RAM stability IMO, and it does not choke on very large installs 2565GB and higher!
