341 - 360 of 779 Posts
Hi guys,
I am new here too. (so any friendly comments welcome ;-)
a.t.m. I tickle a little more speed out of my new e8200. Here is what I got stable (12h primetested).
System Infos:
CPU: E8200 2.66GHz @ 3.48GHz (42°C load temp)
RAM: G.Skill (4GB Kit) PC800 @ 870 MHz
http://valid.x86-secret.com/show_oc.php?id=345161
BIOS Settings:
CPU Host Frequency: 435
Clock Ratio: 8x
Memory Multiplier: 2.00
PCI-E: Auto
C.I.A.2: Disabled
BIOS Voltage Settings:
CPU Voltage: 1.375V
DDR2 OverVoltage: +0.2V
FSB OverVoltage: +0.2V
(G)MCH OverVoltage: +0.2V
Cooling:
Antec Nine Hundred (Case) + Scythe Ninja Plus (CPU Cooler)
So tell me: Am I kicking him too much?
-aCid
am going to try and hit 4ghz sometie next week maybe
Processor Model: Core 2 duo E8400
CPU Clock Speed:3807.3mhz
CPU Bus Speed:423mhz
CPU Multiplier Setting: x9
CPU Core Model: Wolfdale
CPU week/stepping: 6/6
CPU Voltage:1.32v
Motherboard: Asus P5k premium
Cooling: Zalman cnps 9700
Dividers:5:6
Stepping/Revision: 6/CO
http://valid.x86-secret.com/show_oc.php?id=346528
Stable with 1.38125vcore.
Intel Extreme 1366
E6750 @ 3.60ghz
BIOS: 1.463v
CPU-Z: 1.424v
Vdroop: 1.400v-1.392v
Need to get better cooling though. OCZ Vendetta 2 coming soon.
Processor Model Dual Core E2140
CPU Clock Speed 3400Mhz
CPU Bus Speed 425
CPU Multiplier Setting 8
CPU Core Model Conroe
CPU week/stepping Q729A021
CPU Voltage 1.45
Motherboard DFI LP LT X48-T2R
Cooling Water
Dividers 1:1
Stepping/Revision D/M0
Thx
I had 3.8ghz on my old P5KC last week with DDR2-667MHZ Ram (400*9.5) but as i'm upgrading to SLI, i needed to get a new board.
Here's my current stable settings with the E8500 and the P5NT-Deluxe:
OS: XP Professional SP3
BIOS: 1001 /nForce 9.64
CPU: E8500 OC @ 3.6 GHz, FSB (QDR) @ 1515 MHz
RAM: 4 x 1 GB Kingston @ 1066 MHz
GPU: ASUS 8800GTX (Forceware 169.21)
CPU FAN: Zalman 9700LED
Bios Settings
Extreme Tweaker
FSB Memory Clock Mode [Unlinked]
FSB (QDR) 1515mhz
Memory Frequency DDR - 1066mhz
Overclocking
Memory Timing Setting - Manual - 5,7,7,25,33
Spread Spectrum Control - ALL [Disabled]
Virtualization Technology - Disabled
Speedstep - Disabled
CPU Multiplier - 9.5
Over Voltage
Core Voltage - 1.19375v (tested 8hrs prime95)
NEW Core Voltage - 1.17500v (testing)
Temperatures
IDLE MIN
Motherboard 43C
CPU 47C
STRESS MAX (Prime95)
Motherboard 46C
CPU 68C
PS Ignore the Everest Temperatures, it's set for Tj Max 105C so the Core Temps are all 10C higher than RealTemp.
At least, I really hope the Tj Max is 95C on the E8500's
If anyone can help me to get my temps down even more without any new gadgets (this motherboard is 10C hotter than my old P5KC) i'd really appreciate your help...
Thanks
Hey all, First post here. Nice forum.
I've got my E8400 running at 3.65 stable on air (Zalman 9700). I've also got my ram stable at 4-4-4-12 at that speed (Corsair Dominator). It runs at ~35 idle and ~52 under load.
Processor Model
entium dual core e2160 rev.l2
CPU Clock Speed:2908
CPU Bus Speed:232
CPU Multiplier Setting:9 default:9
CPU Core Model:conroe
CPU Voltage:1.3750 bios
Motherboard:msi p35 platinum
Cooling:intel stock hsf
Stepping/Revision:stepping:2 , revision:l2
SuperPI result (1M) - Mod 1.5 validation version
100% stable
orthos 9 h 26min no pic
occt :
cpuz
good luck
Processor Model Xeon Quad Core Server x3360
CPU Clock Speed 2.83Ghz stock 3.825Ghz Stable OC
CPU Bus Speed 1800.2Mhz
CPU Multiplier Setting x8.5
CPU Core Model Yorkfield
CPU week/stepping Packaged March 6, 2008, C1, Batch # L803A762
CPU Voltage 1.33v
Motherboard Asus Rampage Formula
Cooling Thermalright Ultra 120 Extreme lapped
Dividers
Stepping/Revision 7/C1
SuperPI result (1M) - Mod 1.5 validation version 12.2sec
Processor Model Core 2 Duo E8500
CPU Clock Speed 4408MHz
CPU Bus Speed 464
CPU Multiplier Setting 9.5
CPU Core Model Wolfdale
CPU week/stepping Q803A706 SLAPK
CPU Voltage 1.42500
Motherboard Gigabyte P35 DQ6 Rev 1.0
Cooling Air//Thermalright Ultra 120 with 120mm fan
Dividers 1:1
Stepping/Revision 6 C0
