I need help getting a stable overclock. See system specs below, Ram timings:5-6-6-18 TRC-22 Command Rate-2T. I can get the cpu to 3.4(1700x8). It will post and run fine until I run prime95 with lots of ram tested. This happens when the ram is at its stock settings. I tested the ram with memtest86 for 12 hours with no problems. I have messed with ram overclocking as well when cpu settings are at stock, but I cant even get a post. I tried messing with voltages a little, but im very nervous about that and im not sure how much it is helping. Any help, tips would be greatly appreciated.
btw, one cpu core throws error with prime95 at all stock settings, and the cpu temp sensor is stuck at 21c.
