Intel E88400, more overclock?
374 Views 9 Replies 5 Participants Last post by  Biatch
Just wondering that should I overclock some more.
CPU: http://www.aijaa.com/v.php?i=3747520.jpg
RAM: http://www.aijaa.com/v.php?i=3747538.jpg
Could I get it up to 4.50 GHz..?
1 - 10 of 10 Posts
maybe what kinda of cooling do you have
OMG an E88400, where in the hell did you get that? *JaKe*
Air-cooling, Noctua NH-U12P (+1300RPM). IDLE temperatures are 30-50C and when I'm playing, for example, Crysis, max. 55C.
lol
realy there is only one way to find out. but what are your load temps with prime 95 small ffts
Just tested, +60C.
your temps are going to hold you back. id get a get fan or fans for the heatsink
I think so. I have only one case fan (+3000RPM) and one fan in the heatsink of CPU, not two as usually.
1 - 10 of 10 Posts
