Intel G2 80Gb Questions
333 Views 5 Replies 3 Participants Last post by  eflyguy
Can you tell me the difference between these two G2 models:
SSDSA2MH080G2R5
and
SSDSA2MH080G2C1
I think the G2R5 comes with a mounting kit and the G2C1 does not, but they look physically different too.
1. Is there any specs that are different or does one perform better than another?
2. If I had each one of these could I put them in RAID together or would you suggest me getting both of the same?
3. Would you suggest one over the other? Why?
1 - 6 of 6 Posts
First link does not work.
You would be correct, sir. If you look at the product pictures, the models are the same. The former just includes a mounting kit.
They should be capable of raid.
Nope, not unless you absolutely need an included mounting kit.
Fixed link. I do need a mounting kit since I am using it in my Antec1200 that has 3.5" bays
Where do you intend to purchase these drives, if I may ask?
teh internets
SSD access times are so much faster than HD, I pulled one of the two X25's I had in RAID-0 and will put it in another system. RAID-0 gives great transfer rates, but can't see a difference in normal use. Better to get the benefit of SSD in two systems.
..a
1 - 6 of 6 Posts
