My board is a z77 extreme 4 and I have the i5-3570k currently am running 4.7ghz @ 1.27 Volts and it is stable with about 75 max temps. I have also gotten it to 5ghz at 1.35 volts with about 85-90 temps on each core. Since I do not know much about overclock I have only changed the cores to their specific hz and the voltage to fixed. I would like to know if there is anyway to decrease temps with any of the settings on the mobo and also how to work the offset voltage.
thanks!
thanks!
