Intel ITX mobo
268 Views 7 Replies 4 Participants Last post by  hi7of3of2hi9
Hello, I am wodering if I could run COD4 on this mobo.Its got a 7100 on-board. Its probably going to get a Dual core 2.0Ghz or faster with 2Gb of ram. Im probaby going to use this as my low end LAN rig. Also dosent matter if it can run on low settings.
http://www.zotac.com/index.php?optio...per&Itemid=483
1 - 8 of 8 Posts
What resolution? I highly doubt it though...
They do make PCI-E graphics cards... http://www.newegg.com/Product/Produc...82E16814161079
They are all really slow and expensive though.
~B~
The resolution I play at is 1280x1024
The link doesn't work for me, but if it has a pci-e slot, just toss in a graphics card and it should run cod4 just fine. Otherwise no it probably won't run it very well
well it has a pci express 1.0 slot
I was thinking of saving a bit more for this one with PCI-E 16
http://www.ncix.com/products/?sku=36...ufacture=Zotac
Also this ones abit less without PCI-E 16
that board looks good, with a x16 pci-e slot you really can't go wrong..
(looking at it this way, you can get a 780G mATX platform for cheaper..and better)
But if you really want to stick with mini-ITX that can 'game', either go with the pci-e x16 one, or this "A mini-ITX with 780G...but with SODIMM"
And another link for benchmark of 8200 vs 780G..."LINK"
Cheers
1 - 8 of 8 Posts
