I wanted to ask everyone here about the stability argument. I like both brands(have had both) and am glad they both exist, gives us more choice as consumers. So with that out of the way:
I have heard people who build many systems(experts) that a pro for intel builds are that they are more stable than amd builds. Specifically they say:
The answer to this will allow me to make a final decision on if I should do an intel or amd build this time. I like set it and forget it. I would hate to do a build and have constant issues with the bios and software.
thanks.
- Intel has been around a long time and their architecture has not changed too radically from release to release with incremental improvements. Making it stable.
- Intel has better compatibility with a wider range of hardware. Specifically, with ram where you can essentially choose any ram your mobo supports and you are good to go.
- Intel mobos have better designed and more stable bios and driver software.
thanks.
