What drivers do you have installed?
Did you grab the latest ones from Intel's site? I have the same card, and I can do N fine.
I see that, so even if the mode isn't set to have N in it, it will? And how do I check speed?Originally Posted by beers;13135816
What is your sync speed?
Keep in mind the N options are above where you are listing wireless mode.
Sounds good, I will give that a shot.Originally Posted by GH0;13137980
No, I apparently am using the Microsoft Windows Drivers supplied by Windows 7. No idea why.
I have more options then you have however. I would recommend uninstalling via the device manager, and if it asks to uninstall the driver, click that. Then Reboot.
