1 - 12 of 12 Posts
hi people. THIS IS AN I7 SYSTEM i only just got it ( I have yet to change my system specs )
got hold of a ASUS rampage 2 extreme motherboard and I am having SSD problems with it ( stuttering freezing solid HDD light stuck )
now this is not something I was expecting to run into cos the last motherboard that had the ich9r sata controller on it had no problems with SSD's ...how is it possible you can up grade and end up worse then when you started . ?
I just paid shi*t loads for this motherboard and now i got problems.
i only hope there is something that i am missing.
ANYWAY. RESULTS..
CrystalDiskMark 2.2 (C) 2007-2008 hiyohiyo
Crystal Dew World : http://crystalmark.info/
intel x 25m NEW ASUS rampage 2 extreme motherboard
Sequential Read : 248.242 MB/s ICH10R gone to crap
Sequential Write : 59.673 MB/s
Random Read 512KB : 173.778 MB/s
Random Write 512KB : 38.218 MB/s
Random Read 4KB : 24.309 MB/s
Random Write 4KB : 21.744 MB/s
Test Size : 100 MB
Date : 2010/03/26 12:12:36
intel x 25m ASUS P5E. ICH9R
Sequential Read : 246.145 MB/s working fine
Sequential Write : 89.533 MB/s
Random Read 512KB : 159.690 MB/s
Random Write 512KB : 89.358 MB/s
Random Read 4KB : 22.790 MB/s
Random Write 4KB : 69.612 MB/s
Test Size : 100 MB
Date : 2010/02/13 5:47:25
hope you can see what i mean.
Discussion Starter · #2 ·
has anyone got a clue to this or am I going to have to back to slow hard drives.
are you using msachi or intel storage driver? I've found with single SSD that the stock MS driver with TRIM+GC enabled gets the best performance.. in the case of RAID, load latest intel RAID driver.
hmm, if it's non-TRIM then you can just use a wiper util such as in the intel SSD tools package. should restore the performance if that's the issue.
Let's see some HD Tune Pro Random performance and file benchmarks.
Discussion Starter · #8 ·
erm that might be a problem cos I don't have hd pro..is there anything else i can use to test.
Discussion Starter · #9 ·
turns out that the problems is mainly down to writes and not reads.
but i am still not to sure how to go about this. cant get crystal mark to go over 60MB/s ( ment to be 80MB.s) on writes no matter what I do ....I'm starting to think there is some kind of floor in the ICH10R controller. for the time being I cant use the SSD, and i am not upgrading any time soon. ( I just did)
if your installing stuff computer freezes and you have to wait, if you copy stuff computer freezes, if your just opening apps its oK.
the motherboard is awesome but this is a big let-down
hi this is just an update.......since i moved over to windows7 x64 the intel 25m is now just as fast as it was when i was using the older asus p5e....
so it was not the motherboard is must have been something with the drivers for xp....
just use windows 7 .
don't worry about that. i get the same speeds. its blazing fast. remember that if you have any raid configuration that not to be in achi mode but raid mode so your computer can detect it also your speeds probably increase. i ran achi mode and it took me 1:30 for boot but raid config in bios took me 30 secs. idk what to tell you really
1 - 12 of 12 Posts
