Intel's HT rocks
432 5
A few days ago I switched from a normal Pentium 4 to a Pentium 4 with Hyper Threading Technology. And oh man, it just rocks. I can stress test with OCCT while running Internet Explorer, AIM, iTunes, all simultaneously and very smooth. Before I can only run OCCT, and every other applications lags while using it. But 1 real core and 1 simulated core are better than 1! I'm amazed.
1 - 6 of 6 Posts
Originally Posted by Remonster
Thank you Captain Obvious.....
Thank you Useless Poster...
anyway, glad you were finally able to see what ht can do wu, youve been missing out...
... it can do even more tho...
Well, to the best of my knowledge, there isn't one real and one simlulated core, it's one core that is split up.
I dunno, lol, I'm an AMD guy, I just always that that was true.
You guys are essentially saying the same thing. The one physical core is split between a "real" and a virtual core so that multiple processes are handled better. Although one processes will only show up to 50 percent CPU usage (multi-theaded processes excluded), if just one significant process is running, it utilizes far more than 50 percent of the CPU's actual capacity when HT is enabled.
1 - 6 of 6 Posts
