1 - 13 of 13 Posts
I currently have a ATI Radeon 9800 XT and I was looking to get a nVidia Geforce 7800 GT OC. Would this be a worth while upgrade? Also would I have any complications going to this card?
Yes
Yes
Fill out your rig specs, you have a AGP motherboard though the 7800GT is PCi-E. You will need to get a new motherboard.
Discussion Starter #4
So given that I have an AGP board (one AGP slot and four PCI), my best upgrade would be a 6800 GS? Also if I would go with the 6800 how great of a boost in performance would I see over my 9800 XT?
You would see a TON of preformance gain.. i would get the 6800GS, it's a great card.
The X850 XT PE is the best AGP card out, and will probably be the last AGP card ATI makes. Get it!.......pick me one up while you're at it ;-)
So would this.. http://www.newegg.com/Product/Produc...82E16814130002 be a worth while upgrade of would it be better to spend the extra money and go with the X850 XT PE?
Performance would be very similar and the GS is a fair bit cheaper than the ATI card. Plus, with the GS, you might be able to unlock some Pipelines and Vertex Shaders for extra performance
Need moar megahertz
6800GS pcie version is really good for the bucks but agp version is alot different,425/1000 vs 350/1000 and not as much overclockable so i'd take the x850xt ;pure performance.
or how about an ATI Radeon X850 XT ?
Great graphics card but costly, that is all.
Originally Posted by ENTERPRISE1701
I would reccomend the X850xt as it can be flashed to XTPE unlocking further piplines and or vertex shaders.
No more pipelines or vertex shaders are unlocked flashing to the Platinum edition
1 - 13 of 13 Posts
