1 - 3 of 3 Posts
so my motherboard dont show me the interface setup like where the power and reset goes So i just throw them on and hope it works nothing happen just one beep to tell me that the PC is working fine. But will the BIOS tell you if you put it in wrong or will you just find out once it is broken.
thanks for reading
1 - 3 of 3 Posts
