The Victim:
I really dont know the original brand of this case, as it used to house an old P4 system of my brothers. With the exception of the wierd Pac-Man looking symbol on the side...I can find no marks to identify the manufacturer or model.
This Case does support ATX sized motherboards, but as you can see, really doesn't offer much in the way of cable management options (The Mobo tray is literally just millimeters away from the back panel.
Since space is so limited - The plan is to move the HDD trays to the bottom of the case while adding a turbine mod to the front. Additionally - I will add a top 120mm fan and a bottom 80mm fan to assist in cooling. I do also plan on adding a side window to this with some case lights to brighten her up. Colors to be determined at a later date.
To be quite honest - I'm not sure exactly how I am going to manage any cable management on this thing...but that will be a bridge we cross when we get to it.
The Case from the front:
And from the Side:
The Inside:
And a Close-up of the Front Bezel:
And from the Side:
The Inside:
