1 - 20 of 22 Posts
I am looking to cool my 2600K with water, and I want a case that can internally support a 240 rad. Any suggestions.
This may help:
Don't like HAF cases.
Max budget: ~175$, but I can go up to 230 or so if one case is just hands down better then the rest.
Corsair 650D can be had for ~150 on sale. You can also try the Corsair Carbide series. CoolerMaster also has some. the 690II advanced is a few years old, but still a hell of a case. Also, possibly a few Lancool cases could fit a 240.
I believe the corsair 600t can fit a 240 rad in the roof. The 650D can as well but it is slightly out of your price range.
You can get it for ~150 at buy.com or 162 at Amazon.
Discussion Starter · #9 ·
I will probably get the 690! Thanks for the suggestions guys!
Any thoughts on the 240 RASA kit? Just for my 2600K for 24/7 folding.
Perfect choice. There are better blocks out there but for just a CPU loop but it should be fine. You would probably only see ~5C drop and you'd have to go full custom.
Daniel Symonds
Most cases can now Coolermaster HAF , or the 690 are nice
Someone is selling a Corsair 700D on the forums for $150 with an interior painted white too...would totally get it if I didn't JUST purchase a new case ^^. Rasa kit is great, be sure to get RX!
If you will only cool your cpu get an h100. If you want to GPU's down the road (gonna need more than a 240 for that) then you should go with a rasa kit.
Discussion Starter · #16 ·
I will probably get the RASA kit, just encase I want too GPU cool down the road.
Originally Posted by FlamingMidget;15359219
650D highly recommend for WC especially if you want to use an RX rad.
RX series will not fit internally in a 650D. There is not enough clearance for the rad itself, let alone the fans also.
i've heard you just need to do a simple mod, drill 8 holes offset to one side
1 - 20 of 22 Posts
