I have 2 internal usb ports. I removed the usb ports in the front and put them inside because modded the front of the case to accomodate two 120 cm fans
I wont put my wireless inside the casing lol there will be low signal. My room is farthest from our router.
But with a bracket you could sit an external disk safely
