41 - 60 of 69 Posts
I don't think mines is too much larger than the stealth, it just has more of an edge instead of the slanted corners... I believe I used to have a stealth before I hit the pipes with a screw one day. Gotta check, I hope it's the right size -_-
Discussion Starter · #42 ·
well if you dont mind it sticking out you can still do what i did.
· Long Time Lurker
Looks great, man. Nice job.
Discussion Starter · #46 ·
Originally Posted by freakb18c1 View Post
splice those bit*ches
How about you splice them ***atron. It's the plastic part that connects to the mobo that is blocking the fan, i could however shave off a bit but i saw that it was two separate pieces held together by the clip that hooks on the little thing on the mobo connector.
Discussion Starter · #50 ·
Ah sucks, just got home and found that my rad is too big for the top. Dammit, and I was so excited too. I really don't wanna tear into the plastic top... but I'm seriously considering it.
do you mean the part that holds the headphone jacks and all that?
Discussion Starter · #55 ·
Originally Posted by Nlclock View Post
I saw your pictures and i they look really good
Today im getting my own cm 690 for another build and im going to try to make it watercooled aswel (internally).
If you want some pics, tell me
yea man make a work log
· Premium Member
I did something similar with a dual-pass radiator back in April. The guy who helped me put it together put the build log on Hardware Canucks (we're Canadian, after all).
The log and photos can be found here. I'll be taking new photos when my northbridge cooler arrives from NCIX. I like the taller radiator, to be honest. It makes a statement. I also put chrome fan grills on top of it, and it looks great.
Nice job on yours.
· Freeflushots
Nice and clean. I did this with a PA120.2 but had to cut the very end of the front panel PCB off to get a clean "rectangle" shape on the top.
41 - 60 of 69 Posts
