If it came with the nvidia 8600m gt graphics card, you should be able to watch HD movies, despite the lower clock speed of your CPU--I can watch full HD movies with my cpu at stock 2GHz, and I never go above 35% cpu usage when doing so--since the graphics card is doing the decoding. I think your graphics card should do the same, though I don't know of any differences between mobile and desktop gpu's. It will also depend on the drivers you are using for your graphics card--only from a specific version and onward was the gpu used for HD video decoding. Might be something to look into...
