1 - 10 of 10 Posts
I was just w0ndering , since gpus have very nice design, BUT, you cant even see it because the actual design is facing down -.-, so i was thinking if there is any actual card that has inverted pcie slot so the design of the card is facing upwards
They are never going to do that because it is standardized.
Now BTX motherboards are in a way flipped ATX motherboards, but very few were actually made for consumers and used mostly for OEM PCs.
Now if you want to see your video card you can get an inverted ATX case.
1 - 10 of 10 Posts
