Originally Posted by Bdog Roughly... It means the IP address of the server connected to the Internet that your server is connected to. So you can be else where but go through an Australian server. |
Originally Posted by Bdog <G> That's a good one. It must be a different node you are accessing through. I had this program called "Trace Route" and it showed every node and the time it took go to whatever website you went to. Even to the same site it didn't always use the same path. |
