1 - 20 of 24 Posts
im thinking about getting a new motherboard to go with a 6400 c2d (maybe 6600 dependign on moneys).
tomshardware have made me re-think my options, i was thinking abuot the AW9D max but after this article http://tomshardware.co.uk/2006/10/10/cheap_thrills_uk/ that shows an ABIT AB9 pro providing an awesome overclock to a 6400, my decision is swaying.
as far as i can tell, the iP965 chipset is arguably better at this moment in time for overclocking (higher FSB's seem to be possible) but the 975x chipset will be a better investment as its newer and supports more features.
money is an issue but if it comes down to 30quid either way and one is considerably better i will obnviously go for it.
i may be completely wrong but i would appreciate any advise that can be offered.
p.s i am a kean overclocker and the potential speeds are what really matters to me, a 56% overclock strong appeals to me
I have heard much better things about the 965 than the 975 from many trusted sites including toms hardware. I would go for that if I were you.
Discussion Starter #5
arg, and there i thought this was going to a be straight foward answer...
what do you mean by a "northbridge clock strap"? because i keep hearing that 975x chipsets keep getting stuck at around 350FSB whereas ive seen lots of overclocks on the 965 that go well above 400FSB
I remember when......
FYI, the 975 is OLDER than the 965. The 965 was designed specifically to run the Core 2 Duo chips.
It greatly depends on what you feel is most important and what you want. The 975 runs dual video cards faster, the 965 seem to hit higher FSB....some have found a strap at around 400FSB IIRC, but that is still higher than most seem to get on the 975......the 965 is supposed to have a better, faster memory controller.....it doesn't appear to be fully realized yet, but likely a BIOS update in the future will let it loose.
Truthfully, going with one of the high end boards from ASUS, ABIT, or Gigabyte for either chipset, you really can;t go that wrong...the differences between most of them is fairly minor.....I would go with the 965 simply because it is newer and has already lept forward with BIOS updates since it's release, at least on the ASUS side....and full speed dual video cards really isn't that important to me, so far my single X1900XTX at stock speeds is handling even my huge screen very well although I haven't fully stressed it yet.
For a E6400 and down the 965P will be the better chipset (and it is newer then the 975) for an E6600 and up the 975x is good. But the 965p has higher FSB capabilities.
Discussion Starter #9
thanks guys youve really cleared that up, i assumed the 975 wsa newer purely because it seems to have a higher price tag, what asus motherboard would you recomend? so far ive only really been looking at the abit ab9 pro purely because its the only 965 ive heard much about. the prices seem to go up a little for the asus but i think its worth it.
Originally Posted by ThaWaxShop
P5B Deluxe is your best bet
Unless you want to be able to go Crossfire with that x1900xtx.....
Or run SLI higher than 8x / 4x
975x for the long run.
Definately a 965P considering its an E6400.
The P5B deluxe (that Chozart metnioned) is very good and will serve you well. If you want to go cheaper, go the DS3 by gigabyte, cheaper and go the S3.
The P5B deluxe can also crossfire FYI.
(PS: Crowley = fanboy?)
I didn't realise the p5b could do crossfire, I thought it was cracked sli only
It still has a strap after 400mhz, making it worthless to pass 400mhz until 460mhz or so
How would you be a fanboy when comparing two intel chipsets? Kiss my boots
I'm in much the same quandary between a Gigabyte DS4/E6400 or Abit AW9D-MAX/6600.
nicemates, big Abit fan though I am the AB9 series isn't as good an overclocker as the Asus P5B series, Biostar Tforce 965 or Gigabyte DS3/DS4/DQ6.
I reckon teh DS4 is a bit of a waste. If you aren't going P5B Deluxe, you should go S3 and save the rest.
Just my 2c
Discussion Starter #16
hmmm this really isnt going to be an easy decision. personaly i would rather go for asus pureply because they make the best motherboards (its opinion based dont shout at me). however my friend has the same feelings about about abit so i would consider getting one. ive had gigabyte mothnerboards in the past and ive told myself on many occasions that i will not buy another. i am also not fussed at all about crossfire or SLI, until its twice or at least half the performance again in everything, i dont think the cost is justified. so that feature is not an issue with me.
alot relys on how long my current CPU lasts. (its dying all explained in another thread). but i hear alot more motherboards are coming out in december, is it worth waiting for a clear c2d winner?
I have had my p5b running stable at 470mhz fsb with no effort so will go more and would suit a 6400 allendale for ocing purposes
why?
1 - 20 of 24 Posts
