Why do people have the illusion that Blackberry is better for business then android or iphone. Apparently none of you have ever used activesync.
Also, I keep seeing comments about how "open" android is. You cannot remove everything from the phone if you wanted to, so it's just as "restrictive" as the iphone. Also, once jailbroken the iPhone definitely has the advantage as far as apps are concerned.
Also, you don't have to use itunes with iphone you can sync apps/movies/music through 3rd party apps and transfer them wirelessly over wifi as well.
My roommate has a droid x and the UI is much slower and no where near as fluid as even my iphone 3gs. Same with another roommate that has an android phone (don't remember model off the top of my head) and it's even slower.
Oh and one more thing, you can install android OS on an iphone
you can't do that with android.
