Originally Posted by CaNe
Im running a jailbroken iphone 3G on firmware 3.2 and for some reason last night my phone was fine had 4GB of space remaining then all of a sudden when i woke up this morning and plugged my iphone into itunes it shows that i have 4GB of (orange unknown) used space *** does this mean? i cant txt or do anything on my phone right now....
i must ask if these apps were pirated.
if so, their "shortcut" gets deleted from you iPhone, while the file still remains, if you sync it with iTunes.
additionally, all apps from Cydia go to the "other space", as do the aforementioned apps.
seeing that post of yours, it looks like you should restore your firmware back to unjailbroken 3.2 and re-jailbreak it.
edit:
I am pretty sure you can sync contacts with multiple computers, If not you could try open-sshing into your phone and copying the files of your contacts. I'd post links, but not sure if thats against the ToS, but a google search should help you
