1 - 10 of 10 Posts
Despite EVERTHING going wrong today, i have possibly had the worst day in my life, i go to listen to some music on my ipod and now it only seem to play through the right headphone speaker, i have used 3 different headphones on it and all the same!<br />
<br />
Does anyone know a fix?<br />
<br />
I have a apple ipod video 30gb and using the most recent itunes, Ive had it for a week and its been working fine and i cant send it back because i destroyed the receipt!
That is odd, I would've guessed just the speaker, You have a warrenty?
Reactions: Sin100
Probably call apple. Have you tried other soundfiles? Have you tried twisting the plug a bit (While it's inserted)? (If that helped, you seriously need to get it RMAed)
Reactions: Sin100
weird. Mine only doesnt play through both speakers when i hook it up to my computer speakers. I have to twist the headphone jack to make it work.
Reactions: Sin100
try cleaning the headphone socket, something could be covering a contact
Reactions: Sin100
I had the same problem with non ipod phones.<br />
Twist the 3.5mm jack a little bit to the right, or left.<br />
If it still doesn't work, press the jack in a little bit<br />
That should fix it....
Reactions: Sin100
Discussion Starter #8
ok i found the problem.....<br />
<br />
Seems like the metal has bent back inside or summit.<br />
<br />
I can put the headphone jack half way in and push it to the right and they both play but if i put it all the was in (properly) then it just plays through right, meaning its not touching the metal on the left hand side.<br />
<br />
the apple videos are CRAP!!!!<br />
iv had it for a week and my screen is almost unreadable its that scratched up and iv been taking extra care also!!
Discussion Starter #10
Yea and i use that little soft bag i got with it, my older 4th gen black & white 20gb ipod is awesome, it never broke, i could throw it around and not a scratch.<br><br>
I'm gonna see if i can send it back and get them to replace it with a brand new one then put some invisible shield on <img alt="" class="inlineimg" src="/images/smilies/smile.gif" style="border:0px solid;" title="Smile">
1 - 10 of 10 Posts
