1 - 9 of 9 Posts
A unit that takes system ram and makes it function like a hard drive.
It is a device that allows you to load your OS and applications off RAM instead of a hard drive. Manufactured by kingston first i think. It's blisteringly fast...if you are Bill Gates and have a swimming pool and a half of cash.
We need some PCI-E 16x Cache drives, or something similar.
GigiByte has PCI card types that support 4G...<br />
<a href="http://www.gigabyte-usa.com/Products/Storage/Default.aspx" target="_blank">http://www.gigabyte-usa.com/Products...e/Default.aspx</a><br />
They also have a future product that goes in a 5.25 bay that supports 8G.<br />
<a href="http://www.techreport.com/onearticle.x/10116" target="_blank">http://www.techreport.com/onearticle.x/10116</a><br />
<br />
Basically it hooks up to a SATA port and works like a HD.
I still wanna see a $10,000 10gb Cache drive...
DOwp. it the concept of RAM for a HDD takes of we won't need RAM on the MB! Like the current swap file on a HDD, having the swap file on a RAM drive so what good would RAM modules be, none!
<tr>
<div>
Originally Posted by <strong>swayne</strong>
</div>
<div style="font-style:italic">how mutch ram would u need to make it worth while</div>
</td>
</tr>
</table>
</div>RAM needed to make it worthwhile = RAM installed<br />
<br />
AKA there is no answer to that question other than your own.
1 - 9 of 9 Posts
