1 - 10 of 10 Posts
Originally Posted by pauldovi
What about the last number?
The TRAS setting can be a bit odd sometimes. For instance, my Ram is faster 2-2-2-8 than 2-2-2-5. Test out a few settings and see which gives the quicker SuperPi time.
For high FSB on DDR2 such as DDR2-800 will want to run at around 4-4-4-12 if you run say DDR2-1000 I believe you have to run at 5-5-5-15
Originally Posted by TG Daily
While Intel's chipset specifications officially support 4 clock CAS latencies for DDR2-667 memory only, there is some headroom for AMD to optimize the memory interface for CAS 3. This circumstance could become significant, as the performance difference between the current Socket 939 processors and their upcoming Socket M2 counterparts will be rather small, according to sources.
Its slightly unrelated, the 2nd 1/2 of that was just added as context.
source
1 - 10 of 10 Posts
