1 - 4 of 4 Posts
I am running Prime95 testing heat and I am getting between 47 and 48 C temps. Is this safe? This is with the stock AMD fan that came with the retail processor.
Thats fine but if you want to overclock any further and have it be safe, Upgrade your cooler. That's just around what you want for max load. I try to keep max load under 50 at all costs.
Those temps are perfect for load. You could actually get a little more out of it with the stock cooler..
Upgrading the cooler to a better one would allow higher overclocks, good start
1 - 4 of 4 Posts
