1 - 20 of 37 Posts
Looking for a futher upgrade! Mainly due to my x700 finaly taking a well deserved flight across the room. I got this newer 630 prescott running wonderfully. I just ordered the Zalman cnps7700 120mm. I also upgraded from pc2 4200 to pc2 5400 with nice timings. Now i need a gfx that isnt total crap like the x700 was from day one. I dont have a ton to spend maybe 200 MAX. Im looking at this evga 6800gs. Its Cheap and has good reviews. Is there something better for the money i should look at? PCI-Express and has to be Nvidia. Thanx for the input guys!
For a card with features the 6800gs is the way to go. i would buy one personally.or if you have the money i would buy a 7800gt you should be able to get one really cheap as they stopped making them.
edit: you really can't be mad at ati for having a x700 card because the x800/850 and the x1k series are all very nice.The x700's are all terrible cards.
Thanx for the input Ill look for a cheap 7800 but i think the 6800gs will be the one i go with less i find a crazy deal. Im sure some of ATIs stuff is nice but i will NEVER load catalyst drivers EVER EVER again. All the issues i have ever run into with ATI seem to be driver based. Anyone else hate ATIs software?? or do i just sux0r at life.
Well you should have said that.I hate ati drivers. I've had four programs tell me i couldn't do something cause of the "untested drivers".Anyways i'l probably go back to nvidia soon as i feel they have a higher quality product but i would live with ati if i had too.
Discussion Starter #6
Wow great post Ropey. Thats a big help. Im looking at more like 70-120$ difference but there is one for under 200 so that would be the way to go! Thanx man!
What kind of condition is that X700 in? I might be interested in buying it from you if it still works and is PCI-E
Discussion Starter #9
Yeah im thinking 7600gs now. Newegg has the Evga which is clocked higher than the XfX stock
http://www.newegg.com/Product/Produc...83#DetailSpecs
The X700 still works and is in fine shape. Its an ATI (not evga, bfg, asus, whoever) and its the Pro with 128mb GDDR3. I would be willing to sell it cheap but i suggest you find something better. Feel free to make me an offer thow!
..you must sux0r at life then, because I've always thought very highly of catalyst, I like it a lot better than forceware.
The 7600GT runs cooler, but may be about the same noise level. I think you should get the 6800GS to save some money. Plus it's unlockable to 16 pipes so it really is a 6800GT. My friend got it and he's very pleased. It won't work on his computer but it works on his dad's though.
Let me get this straight. Because he likes something you don't he must "sux at life"?
Is this what you meant?
R
How many megs is it?
R
haha it was meant to be a joke, I wasn't being a smartass, so lay off.
i have a leadtek 7600gt, tis a good card. Scored 5.7k 3Dmark05 with my rig all at stock. the cooler is a bit loud but other then that i am very happy with it.
I was just trying to figure out what you meant since you posted no smiley faces indicating that you were making a joke.
Thanks for letting us know you were not being serious. Now we know that you do not just "Sux0r at life".
R
Discussion Starter #17
yeah no worries about "sux0r at life" i said it first! lol Alright so the 6800gs will ALWAYS unlock to (16?) pipes? This still wouldnt beat the 7600gs would it?
As i posted the x700pro I have is a 128mb Gddr3 made by Ati
EDIT:: actually after checking RivaTuner its showing its a 256mb card. Im almost sure thats incorrect thow. how can i check? Its showing 425.3core and 432.0 mem
Your looking for PCI-e right? The AGP 6800GS usually unlock (not heard of it not unlocking yet) none of the 6800series on PCI-e unlock.
Well, it seems like the 7600 GT is just a little better than the 6800 GS.
On a side note; Damn it! I just bought this fricking 6800 GS, had I known the 7600 GT was about to come out, I would've bought that one instead. But I'm not at all disappointed with my 6800 GS, I like it a lot.
1 - 20 of 37 Posts
